Cars & Trucks Logo
Nathan Ford Posted on Nov 17, 2013
I have a 2007 dodge ram 1500 3.7 v6, I'm having trouble with my pioneer stereo! I have everything perfect but when my stereo goes off it resets! What color is the memory wire?
Larz weber
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 17, 2013
Larz weber
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
129
Points
It is usually called the remote wire. Either solid light blue or light blue with a white stripe. On the back of the pioneer deck look for the wire labeled REM+ it's just a 12v constant.
  • Nathan Ford Nov 17, 2013
    Yes, I know the remote wire on the pioneer is blue w/ white stripe, but on the dodge is what I'm having trouble with
5 Related Answers
Anonymous
  • Posted on Jan 03, 2009
SOURCE: need stereo wiring diagram
1998 Dodge Ram 1500 Truck Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Behind the glove box.
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Anonymous
  • 512 Answers
SOURCE: 2001 dodge ram 1500 v8 spark plug wire diagram
the firing order is 1 8 4 3 6 5 7 2 clockwise around the cap
Anonymous
  • 379 Answers
  • Posted on Jan 10, 2009
SOURCE: 1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Anonymous
  • 54 Answers
  • Posted on Feb 01, 2009
SOURCE: 2004 dodge ram 1500 rear brake light out how to replace?
Open up the tail gate, you will see two torque screws on the inside beside the tail lights. take these out, this will free up the housing and you can change it from there.
ZZZoom
  • 151 Answers
  • Posted on May 10, 2009
SOURCE: check engine light on code
This trouble code is Evap Purge System Performance fault. 1) Check for a loose or missing fuel cap. 2) Check for a damaged or missing fuel cap seal. Recheck for other trouble codes. This fault wont cause the stumblering problem. It turns on the MIL lamp to say there leak in the EVAP system.
2answers
2008 Dodge Ram 1500 5.7 Wire diagram stereo where do I connect the blue remote wire
https://www.modifiedlife.com/2008-dodge-ram-1500-radio-wiring-diagram/
Firing order diagram for 96 dodge ramp 1500 van v6 3.8 engine
Note this information, about Dodge RAM 1500 have 3.9 engine... 1996 Dodge 1500 Pickup 3.9 liter V-6 VIN "X"
This is for one 3.8L V6 1996 Dodge 3.8 liter V-6 VIN "L"
Hope helps (remember rated this).
1helpful
How do you remove radio from 2007 dodge ram 1500
the trim around the radio just pulls off and then the stereo is screwed in
1helpful
2004 Dodge Ram 1500, Infinity sound system. CD/AM/FM not working.
You most likely need a new radio. They go bad all the time in the Chrysler/Dodge/Jeep. Don't know how many of them I have replaced.
3helpful
Check engine light on code p0441 dodge ram 1500 my 2007 dodge ram 1500 is puttering and acting like it wants to die out can you let me know what the problem is.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
