Refrigerator is no longer getting cold
It is possible that if the compressor is running that it is either low on freon and not cooling or in some instances low on freon and evaporator is froze up - in which case frig will cool again once all the ice has melted on your floor,) Or maybe your compressor is not running - in which case its cheaper to get a new frig for sure. Listen to tell if the compressor is running. If it is, then your frig probably is low on freon. (I don't know if yours is new enough for a timer) Hope this helps you, Rick
SOURCE: AMANA BG21VL REFRIGERATOR ISN'T COLD,
check in frezzerto see if your evap fan is blowing if not need to replace it if its is u will have a defrost problem u can unplug for 4 or 5 hrs with doors open to defrost itsself . plug back in will work fine till u can replasce heater and tsat.
SOURCE: Refrigerator does not get cold and the freezer does not freeze.
look on the back of the box for a hole marked defrost control timer turn the timer with a screwdriver if it then gets cold replace the timer
SOURCE: Refrigerator is not getting cold
the evap fan motor sounds like its not working . replace the fan motor and the defrost terminator .. ..mm
Hi
Check the freezer to ensure it isn't over loaded with food stuff; reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly. Also check whether the unit needs defrosting or not. You should also check the coils on the rear of the refrigerator and make sure they are clean and dust free. If you still have problems after trying the above; you may need to call a repair service to come out and check the unit
Please check the bellow links to have a detailed idea related to your issue:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnotcool
http://www.appliance-repair-it.com/refrigerator-not-cooling.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
