SOURCE: 1991 jeep wrangler gas leak
Hello everyone,l
For those of you who haven't started removing the gas tank, I'll start from the beginning.
You will need a 1/2" socket, ratchet, extensions, flat head, needle nose, floor jack, rag, broomstick,. A creeper will make this easier. Depending on your dimensions and the height of the frame on your particular vehicle, you may be able to use it without jacking the vehicle up..
If you were experiencing a line leak, the top of the tank is where you'll find it. Inspect hoses, gaskets and connections
SOURCE: 2007 chevy silverado slow filling gas tank
vent tube must be blocked off, check the tube first, thanks robert b.
SOURCE: can't put gas into 2004 silverado
tank has a check valve in entrance to tank some are in the filler hose some are in the tank neck where filler hose goes onto tank ,remove hose to check it some holes are only the size of 25c where check valve flap is(this causes lots of problems another great idea from gm)
SOURCE: my 2005 silverado 5.3 fuel problem i think
Sounds lik a fault with the fuel pickup pipe, will require petrol tank investigation.
SOURCE: The heat shield underneath the gas tank broke off.
NEED HEAT SHIELD PROTECT GAS TANK FROM HOT EXHAUST PIPES.GO TO SALVAGE YARD FIND HEAT SHIELD.IF YOU CANT FIND ONE.CHECK OTHER GARAGES OR GO ONLINE INTERNET FIND ONE CHEAPER.I WOULD NOT DRIVE CAR WITH OUT HEAT SHIELD PROTECTING GAS TANK.SINCE GAS TANK IS PLASTIC.
