I have purchased an i68 and I can not get MMS text from anyone.
I've tried numerous settings... can someone who has Cingular/AT&T please tell me the settings they are using to receive MMS text?
I can make calls and receive regular text but thats it.
thank you
Hi there I have the same exact phone these are the exact settings I have on my phone.
first you will need to create your data account.
select services
select data account
select GPRS
select first entry
edit account name to ATT
press options then press done/ok
edit APN to wap.cingular
edit username to [email protected] (UPPERCASE)
EDIT PASSWORD TO CINGULAR1 (UPPERCASE)
AUTH TYPE TO SECURE THEN SELECT DONE AND SAVE.
NOW TO SETUP MMS SETTINGS
select mms then select mms settings
choose edit server profile or edit profile
select the sim card you are using
click edit profile
rename profile to ATT MMS
press options press ok
edit homepage to http://mmsc.cingular.com
edit data account and select ATT
select http and choose http ip address is 066.209.011.032 and the port is 8080
username is [email protected]
PASSWORD IS CINGULAR1
SELECT SAVE AND YOU ARE ALL SET, ENJOY YOUR PHONE.
hi there I have the same exact phone these are the exact settings I have on my phone.
select services
select data account
select GPRS
select first entry
click edit profile
Find here an english user manual for SciPhone i68
This includes MMS and GPRS settings for major providers (also AT&T)
SOURCE: i cannot "forward" any of my text message in my inbox
For forwarding sms messages, i click on the sender and the next screen will be "call number" and the next line is "send text message". I then click the OK button and the messages will be highlighted in blue. Under menu the press "forward".
there may be a shorter way but havent found it yet
SOURCE: text message problem with sidekick slide
Well for the past week or so, Sidekick has been having problems with receiving text messages from other service providers such as AT&T and Sprint. It is best that you call up customer service to find a solution.
SOURCE: Unable to text
problem is still there after confirmation of message centre number.
I think the only solution for this problem is to reinstall the software coz this particular problem in N73 is a common one. So am also about to reinstall the software.
SOURCE: sciphone I68, service provider ATT, GPRS not subscribed
WAP
***First Step***
1.Main menu --> Select Services
3.Select Data Account --> Select GPRS
5.Select the first entry
6.Edit the account name to whatever you would like
7.Edit APN to wap.cingular (lowercase)
8.Edit Username to [email protected] (UPPERCASE)
9.Edit Password to CINGULAR1 (UPPERCASE)
10.Edit Auth Type. to Secure
11. Save
Select Back --> Select Back
***Second Step***
Select WAP
1.Select Settings --> Edit Profile
3.Select the first entry --> Edit Profile
5.edit the name to whatever you would like
6.Edit Homepage to http://device.home
7.Edit Data Account to the Name you established in the First Step
8.Edit Connection type to HTTP
9.The IP address is 066.209.011.032 and the port number is 8080
10.Edit Username to [email protected]
11.Edit Password to CINGULAR1
Select back or done
Select Activate Account
You should now see a Black [G] in the upper left of your screen.
MMS
Select Messages --> MMS --> Message Settings
Select Server Profile
Select Edit Profile
Edit Rename Profile to whatever name you would like
Edit Home Page to http://mmsc.cingular.com
Edit Data Account to the same data account you created for WAP
Edit Connection Type to HTTP the IP address is 066.209.011.032 and the port is 8080
Edit the Username to [email protected] (UPPERCASE)
Edit the Password to CINGULAR1 (UPPERCASE)
Select Done or Save
Make sure to activate the profile and you are good.
Just be Patient and make sure you double check everything you put it it has to be exactly as it says.. I just set mines up yesterday and it works fine.. Hope this helps! It took me forever to find the solution hah
SOURCE: hello i just received my sci phone i9 +++ today
Every body know how to reset or hard reset the phone i9 from China? my phone can not side to unlock .Thanks
