Casio FX-300MS Calculator Logo
Posted on May 05, 2009
Fractions how to put fractions on the casio fx-300MS S-V.P.A.M. calaculator
Anonymous
Level 1:
  • Contributor 8 Answers
  • Posted on May 06, 2009
Anonymous
Contributor
Level 1:
Answers
8
Questions
0
Helped
31063
Points
35
There is a A b/c button. This is the button use to enter fractions. so 4/3 would be entered as 4 |A b/c| 3
If you want to have the answers in fractions as well, then I believe you hit more a few times. And then there should be a display option, in the display option, there should be a b/c. This will show your answers in fractions. Hope it helps
1helpful
How do I minus fractions on my fx-300ms
The same way you do positive fractions. Just make sure you use the (-) key located just above the RCL key to enter negative numbers.
I'm trying to do fractions on my casio fx-300MS S-V.P.A.M. can you help me
if you need to use fractions, look at the symbol the second button beneath the RED ALFA button.
2helpful
Can you convert a decimal to a fration on the fx-300MS scientific calculator? If so how?
To convert a fraction to a decimal or a decimal to fraction you use the [a b/c] key.
While converting a fraction to a decimal number is always possible, converting a decimal to a fraction may, at times, not be possible.
How do i change a decimal into a fraction on a casio 300ms
Assuming the number is something that the calculator can convert to a fraction, press the S--D key.
2helpful
2answers
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
How do I key mix number fractions on the Casio 300MS Calculator?
Use the [ab/c] key
1[ab/c]2[ab/c] 3 displays 1u2u3. Pressing [SHIFT][d/c] converts this to 5u3. Pressing the [SHIFT][d/c] again converts the result to 1u2u3
Hope it helps.
Dividing fractions
Once a fraction is entered it can be submitted to all allowable operations, like any other number. So keep the fractions coming. The calculator will reduce them to their simplest expressions.
Hope it helps.
1helpful
Casion Fx-300MS
If I understand correctly you result do not display any decimal.
If you want a fixed number of decimal digits (exemple 2) Press the [MODE] key a number of times until you reach the screen that displays Fix Sci Nom and under them the numbers 1 2 3
Press 1 to choose Fixed format followed by 2 for TWO Digits
3 decimal digits [MODE] ---------[1 ] (Fix) 3
Hope it helps.
1helpful
Casio FX-300MS - Simplifying Radicals
Sorry the calculator handles fractions but not radicals. You may be interested in the newer Casios FX-115ES, or FX-991ES, (Natural display).
It handles a lof more that radical and fractions.
Hope it helps.
Fractional powers
use the "carrot" button, ^. Type in 4^.5 and you get 2. If you are going to use fractions, use the division bar and parenthesis and not the fraction key. Example 4^(1/2) = 2
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
