Question about Garmin (010-00583-00) for nuvi 750/760/770
My Nuvi 750 has stopped talking, still shows the map but no voice
Posted by kdbrown on
Anonymous
That has happened to me several times. When it happens I go to Tools > Settings > Language. In my case, the Voice field is empty, so I click on the Voice field and then select American English-Jill (TTS) and it's okay afterwards.
Posted on Jul 15, 2009
Anonymous
Go to tools>settings>volume. At the bottom of the screen is a button for "FM Transmitter" Select the tFM ransmitter so the screen opens and check the box to disable the FM transmitter. You should now get the voice of whoever you have selected in the languages function..
When the FM transmitter is enabled, then the unit is sending an FM radio signal to your car's radio on the frequency identified in the FM transmitter box. The purpose of this function is to play the audio from your garmin unit over the speakers in your car radio. If you wish to use this feature, you might have to have the unit search for a different FM frequency that is not in use in your area.
Posted on Aug 30, 2009
Anonymous
  • 3 Answers
I got mine to talk again by running the battery down to almost empty. It's working fine now.
Posted on May 24, 2009
No french laguage
On the Nuvi 7xx series as well as many other nuvi models, voice updates are free and downloadable from garmin.com. Garmin only charges for map upgrades. Maps do not contain voices. I have backups of french text to speech (TTS) voices. I would be happy to give you links to download them to you.
Mar 05, 2014 | Garmin nuvi 750 GPS Receiver
I have a Nuvi 650 which seems to be muted. How do I get it to talk again?
1.
  • Press the volume, the speaker icon at the bottom right of the screen showing WHERE TO and VIEW MAP
  • On the volume screen there's a tick box for MUTE. If it's ticked press it and the tick will be removed. The satnav should then not be muted.
2. If this doesn't solve the problem it may be that the voice file is corrupted.
  • Press TOOLS
  • Press SETTINGS
  • Press LANGUAGE
This brings you to a screen with VOICE, TEXT LANGUAGE and KEYBOARD
Press VOICE and select another English speaking voice. This may solve the problem.
3. If you don't have another English speaking voice;
  • Download the latest version of Webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it to your computer
  • Connect your satnav to your computer and run the Webupdater program
  • Webupdater will find any software updates for your satnav. Install them. When the installation is complete it will find optional updates including voices. Select some English speaking voices and download them to your satnav.
  • After you have disconnected your satnav from the computer you'll need to select a voice again as described in paragraph 2 above.
Jun 03, 2011 | Garmin nuvi 750 GPS Receiver
How do I change language on Garmin Nuvi 750?
  1. Press TOOLS (The spanner symbol on the screen that shows WHERE TO and VIEW MAP)
  2. Press SETTINGS (The spanner symbol)
  3. Press Language (The lips symbol)
  4. There are 3 items on this screen VOICE, TEXT LANGUAGE and KEYBOARD
  5. If you need to change the voice to english press voice and select an english voice.
    If you need to change the text to english press TEXT LANGUAGE and select english
Oct 02, 2010 | Garmin nuvi 750 GPS Receiver
The voice is not talking anymore
The Garmin 750 has a software bug that happens if "loading Maps" takes a long time. The voice gets changes to "Afrikanes" or "none"and won't work. To fix go to tools , settings, language check voice settings for prpoer selection.turn unit off and after 20 seconds turn back on this should reset the voice settings. Check your software version the latest from Garmin is 4.80
Aug 31, 2009 | Garmin nuvi 750 GPS Receiver
No map dat a available
who need to hook it up to the computer and download the maps back in to the Nuvi. Kinda reprograming if you will. the Garmins usually dont come with the usb cord to conect to the computer but you should be able to buy one. hook it up and download all the maps and you should be good to go. Oh by the way they have lots of cool fetures to download on the Garmin website cool cars and voices, although i prefere for mine not to talk. Good LUck
May 24, 2009 | Garmin Nuvi 350 Car GPS Receiver
My Garmin nuvi 750 is no longer talking to me. There is no voice. When I go to the language settings, the Voice shows none found. It was working 2 weeks ago, I haven't used it since. Our Garmin had a...
There is a software bug Garmin has been working on for a while. The voice file changes to none. To fix go to tools, settings voice and change to desired language. Sometimes the language files get messed uo and need reloaded from webudater, this can be obtained from www.garmin.com. The latest Garmin Software version is 4.80
May 06, 2009 | Garmin nuvi 750 GPS Receiver
Garmin 750 stop saying street names
If you go to your languages, in the menu
Check Languages are
(( noted with a person's name ))
these are TTS text to speach voices,
Check they are set correct,
you should be good.
Hope this helps
Regards
Richard.
Apr 11, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
No voice prompts on my new nuvi 750- volume level not muted.
I had the same problem after I had my Nuvi 750 for a few months.  The voice just stopped.  I called Garmin and they replaced it under warranty.
Feb 11, 2009 | Garmin nuvi 750 GPS Receiver
NO SOUND ON GARMIN 750
I had the same problem. I fixed it by going to settings, then to language, and then entering American English into the Voice category. Hope this helps.
Nov 19, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
My garmin nuvi 205 quit talking. volume is at 100% and not on mute. beep sounds work but when in route i have no next turn or direction sounds. screen map does work.
I have a 750. I went to settings, language and restored the defaults. The Voice was blank when I went to that screen. I am not sure if the 205 has the language setup or not, but this should solve other Garmin problems. And as a bonus, if you want to solve the problems with the US, Fire Congress check out http://FireCongress.org
Nov 07, 2008 | GPS
Garmin (010-00583-00) for nuvi 750/760/770 Logo
1,223 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
