Question about SanDisk 2GB microSD Memory Card
Formatting hi when i insert my sandisk into my pc an error comes up, it says that the disc in drive e is not formatted when i try to format it a message comes up saying that it cannot be formatted please help!!!
Posted by laurakeeney1 on
  • laurakeeney1 May 05, 2009
    how do i check to make sure the SD card in not Set to Write Protected??
Anonymous
  • 36 Answers
Hello Laurakeeney1
I would check to make sure your SD card in not Set to Write Protected, if it is not follow this link for a Flash Memory format utility that I use to fix any problems i have with Flash memory
HP USB Disk Storage Format Tool - v2.1.8
http://files.extremeoverclocking.com/file.php?f=197
Hope this Helps
Posted on May 05, 2009
How i format 8 gb usb sandisk
Usually, it comes formatted. However, you can re-format it (e.g. on a PC or Mac) using the usual disk format utilities, if you don't need any special/specific (SDHC) format features.
For instance, on a PC ... insert the USB SanDisk into a USB port. It will show up as a (storage) device on your "My Computer" window. Highlight that icon ... (put the cursor over it) ... and put your cursor on the FILE (menu) tab and click on it. It will display a drop-down menu with "Format" on it.
Click on the "Format" and it will guide you through the formatting process.
On a Mac, when you insert the USB SanDisk into a USB port, it will show up as a device on your desktop. You can use the "Disk Utilities" software (usually in the Applications - Utilities folder), to format it.
Jan 19, 2014 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I'm unable to format my pen drive. The following error has displayed for each time i tried to format my sandisk cruzer blade"Windows unable to format your drive"
HI Friend..!!!!!
try this
1. Insert your pen drive in computer and don't take it out.
2. Place WinXP Cd in CD-Rom
3. Restart your Computer
4. When your computer prompts boot from Cd click any button
5. Wait for upto 5-10 minutes.
6. Now when format screen comes select your pen drive over there.
7. Now install winXP over to it.
8. Now it asks for format.
9. After formatting it copies the files, at that particular moment restart your computer.
10. Remove the Cd from CD-Rom and the pen drive from computer.
11. Now when your computer is restarted insert your pendrive and delete if there is any unneccessary file exists.
12. Now you'll feel that your Pendrive is in OK condition.
ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards'
sandy
Sep 04, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I can't format my memory card, the error says "Windows cannot format drive. Quit any disk utilities or other programs that are using this drive, and make sure that no window is displaying the contents...
go to computer direct the pointer to this pc right click and select (manage) it will take you to computer management select disc management and select the location of the drive you want format
Feb 11, 2018 | SanDisk 2GB microSD Memory Card
I can't open/ format my 8gb sandisk mdhc..i've tried several app to format it..and it always end up to have ah error in formatting..the other app said it is write-protected..and the size shows only 30mb
Hi there
  1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  2. 2 Open up 'My Computer'. You should see it under the list of available drives.
  3. 3 Check its contents first to make sure that you have the right drive.
  4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
  5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
May 20, 2010 | SanDisk 2GB microSD Memory Card
Pendrive software
if window is unable to format try to format it using some utility software like hp disc format utility
download link
Apr 05, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 2 gb pen drive not doing format insert usb but show u want to format and yes so not working format option so pls given me some importent tips argent
Hello friend,
You can try the following format may this can help.
Try to format the mp3 player like this method:
Go through the : Setting>Control panel>
Administrative Tools>Computer Management>Disk management>
locate you mp3 player then
Try to format fat files system.
hope this help you
Regards
uttam
Jan 08, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I mistakenly formated my mp3 player 1Gb when formating my PC
If there was any driver whit it install it or search the net for a suitable driver
Oct 10, 2009 | SanDisk Sansa m240 MP3 Player
Sandisk Format
JUST PUT IT IN TO WATER,THEM EVERYTHING WILL BE ALRIGHT.
Mar 09, 2008 | Electronics - Others
SanDisk 2GB microSD Memory Card Logo
416 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
ChinthakaJ
ChinthakaJ
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
