Samsung HT-Q100 System Logo
Posted on Oct 07, 2007
Sound Problems with HD TV
Since I bought the System, I have never been able to experience the surround sound of the System purely thru the TV i.e. just regular cable tv programs/shows etc Only when I select it for DVD or for Music does it work. Isn't the point of the System to provide the Home Theater experience at all times. I looked at the Manual, and it makes no reference to this point.
  • 2 more comments
  • njohn00 Jul 01, 2008
    I have a Samsung 40 in LCD T.V and Samsung home theater system (model HT-Z310) I can listen to my ipod and DVD's via the surround sound but not tv shows ect. I purchased the system about 2 months ago.
    Thank you!
  • youandmer120 Nov 27, 2008
    i have same problem i can get sound from speakers when i play dvds and music cds but no sound when i watch normal tv
  • pretzelsb Dec 15, 2008
    I have the same problem. Everything is wired correctly, and when I play DVD's or CD's, the system works fine. However, when I try to listen to tv shows thru the system, I get no sound.
  • Anonymous Dec 29, 2008
    Hi, i have the same problem where DVD's and CD's play okay but i do not get sound now when i am watching Sky? Only ever had one speaker working properly but now both have failed! As one has worked, surely all leads etc are connected properly? Any help...anyone?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 04, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
718
Points
Get the digital audio optical cable and connect the to the tv- got it working tonight
Anonymous
Level 1:
  • Posted on Nov 05, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
718
Points
0
I have spent the last few days trying to get this set-up properly. Getting closer.
Connect 2 phono plugs (red and white i think they are) from your tv, should be "audio out" then connect the other end of these cables to "audio in" on the samsung. If you choose "AUX" on the "source" on the samsung, you can get anything thats on your TV to play through the surround sound. I'm still having problems with the DVD side of things. I connected them using the HDMI cable and the sound from the samsung plays only through the surround sound, not the TV. You CAN selct HDMI Audio "ON" but then you get no sound through the surround speakers.
Basically connected phono plugs from TV AUDIO OUT to SAMSUNG AUDIO in and you the AUX on the source menu on the samsung. This will play anything on your tv through the speakers.
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
4helpful
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
1helpful
No sound
I had the same problem on 3/21/09...I found it was the PS3 settings. I had to go into the visual settings (not sound) and change the linear sound to optic digital...but I also had to purchase a digital optical cable...plug everything into your tv instead of the receiver and then hook up the digital optical cable from your tv to the receiver. A it will work and b it is a better sound quality than that of the HDMI cable.
This seems to be a problem that has to do with your HDMI audio output.
First check in your TV setting if audio out is selected on your correct HDMI port. Than check if your receiver is able to receive audio via HDMI (i assume you used the HDMI connection). Some receivers have HDMI IN connections but are not able to receive audio on it, the latest receivers/sets do have this feature. If your receiver doesnot support audio IN via HDMI you can only do one thing, connect the stereo audio-out of your TV to an AUX IN connection on your receiver.
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
1helpful
I just bought the 52 inch philips lcd tv model number 52pfl3603d. I'm trying to hook it up to my philips surround sound model hts3544 so I can hear the tv thru the surround sound. Watching a dvd is no...
Is the volume on the dish network device turned all of the way dowm?
Is the dish network connected to its pwn input on the SS system and did you turn the SS system to that input ?
Are you using the analog input (red and white) cables to the input from the TV to the SS System?, not from the SS box? This is not the correct setup?
AUDIO
This TV ONLY transfer audio OUT to a ANALOG SYSTEM THRU AND ANALOG SIGNAL. That is, TV will play sound fine in your surround system but any digital (HDMI) wont sound.
2answers
No sound from TV only when playing DVD
Check carefully the RCA conections or others.Sometimes this conections break inwards end cause this problems.Check also the lead and the Set up from surround sound.Verify if the TV has settings for this kind of operation. A strong hug !!!
5helpful
4answers
I have a Samsung HT-X50 Surround Sound, a LG 50" Plasma 50PC5D TV, and DISH Network Satellite.
How can I get surround sound to work on my tv. When I pull up my menu and go to audio the SRS Trusurround XT is not in bold so I cant figure how to connect it so I can have the surround sound coming from the system and not from the tv. Please help.
6answers
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
