Question about Karcher 2500 PSI Pressure Washer
Honda 5hp engine wont run
Its a preasure washer and i bought a new fuel pump and carb, it will run for about 15 secs and shut off, please help, honda gc160
Posted by djjervey9115 on
Anonymous
    Problem Solver:
Check oil level. it has a low level shut off switch ?? May be it
Posted on May 07, 2009
Problem with a tiller Earthquake viper engine either the carburator or carburator gaskets LBLSNMC43
The Viper Engine is a Honda clone. Try a new carb for $15 0n ebay. http://www.ebay.com/itm/NEW-GX160-5-5HP-HONDA-ADJUSTABLE-CARBURETOR-WITH-FREE-GASKETS/121225345625?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D30002%26meid%3Df495007fc18649159ceb1009031e4fad%26pid%3D100011%26rk%3D2%26rkt%3D10%26mehot%3Dpp%26sd%3D261393057447
Mar 04, 2013 | Ardisam Inc Earthquake Mini Cultivator
Honda pressure washer 5hp will only run with the choke on. Was running fine for about 1 hour
The problems you describe are usually indicative of a blockage in the fuel system somewhere in the carburator or a damaged gasket that's letting in too much air. With the choke on, the vacuum in the carb goes way up and forces more gas through. Remove the carb and check the gaskets and insulator if it has one. Then check the float bowl for debris and blow out all the passages in the carb.
Sep 16, 2012 | Garden
I have a honda 5hp pressure washer.I cleaned the carb and now when starts the gas fills the block!
The float needle is not closing all the way and fuel keeps leaking in to the carburetor. Replace the needle and make sure the float is not damaged and that the float pin is clean.
Mar 22, 2011 | Psi 2500 Mobile Pressure Washer 5hp Honda...
Engine stalled out,would not start, pour gas in carb,cranks,keeps running,until idle falls below 12to1500rpm,than stalls out again and will not crank,repeat gas or starting fluid in carb,cranks runs and...
This truck is fuel injected, the problem sounds like a weak fuelpump, it runs when you pour gas into it until that gas runs out, the first thing is to test the fuel preasure, if the pump is weak it may run with gas poured into it but wont idle, also a common problem is the coolant temp sensor and the ground wires to thermostat housing bolt but i wont bet its the pump inside the fuel tank, if you put a fuel gauge on it there should be at least 55-61 psi if its a few pounds lower it can cause problems, you have everything else and it runs with gas poured so its a fuel problem check the preasure, theres a valve up top on the fuel line to connect a fuel gauge to it, start there hope this is helpful.
Dec 27, 2010 | 1993 Chevrolet C1500
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
Honda gx120 starts runs for 45 secs, cut out then will restart 45
Sounds like fuel starvation. there is a small filter insde the tank. if you take the tank off you will see that where the fuel hose attaches to the tank. this spigot unscrews from the take to reveil the filter.
Hope This helps
Oct 01, 2009 | Karcher 2500 PSI Pressure Washer
Honda GC160/ 5hp will not start
Two things here, Pull the line on the fuel tank off replace the in line fuel filter and replace the gas pump bulb if it is bad it will not allow the gas to stay in the carburetor. Also pull plug and see if it has good compression by putting you finger on top of it and move the flywheel till you get compression. Also the governor may be sticking it's connected to the carburetor and the arm that goes inside the engine. But the filter first.
Jul 10, 2009 | Karcher 2500 PSI Pressure Washer
1994 JOHNSON 200 WONT RUN AT ALL WITHOUT CHOKE'ON CARBS CLEAN. WONT DRAW FUEL FROM CARBS COMP GOOD. EX CLEAR ,GOOD SPARK,?NEW TIMING BASE NO HELP. POWER PACK NO HELP. WONT IDLE AT ALL, RUNS FOR ABOUT 10...
If you have a primer bulb and the motor "recovers" after a near stall with a pump of the bulb, then you have to replace your fuel pump. Johnsons do have this problem often. Otherwise it could be the high speed jets although it sounds like you checked the carb good. Also if you have a primer bulb, Replace everything from the tank to the engine. Costs about $14 at Wal Mart, $55 at a boat place.
Jul 06, 2009 | Boating
No high preasure at nozzle
Try starting the washer up without a nozzle clicked in and purging water through the pump, shut it down and install the nozzle and restart, if the motor lugs then it is making pressure, if the pump squirts water out of the by-pass immediately and or constantly it may be a stuck bypass and not a bad pump.
May 26, 2009 | Psi 2500 Mobile Pressure Washer 5hp Honda...
Karcher 2500 PSI Pressure Washer Logo
1,222 people viewed this question
Top Karcher Garden Experts
Bruce Robin
Tim Venetis
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
