This is a desk stapler so may not be in your realm of expertise since it is not heavy duty. I have a Swingline 211xx electric stapler. When I staple, it does not release. I pull the paper out and it has penetrated the paper, but has not bent the staple around the paper. I am using Singline S.F.4 premium staples with a chisel point from the professional Plus series.
If you unscrew 4 bottom screws to lift the top cover, you may find out that there are 2 orange rubbers above its hammer that broke and needs to be replaced.
Check the bottom plate. Directly below where the staple exits the staple head is where the staple is forced into a grove where it is bent back onto itself .. Check to see if its in the proper position .. some are adjustable Good luck
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy
Instructions
2. Check the staples to make sure there are no visible jams. Remove some staples from the row if this helps them fit.
3. If you continue to have problems, contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
They will replace the stapler if needed.
Thanks, but mine is not adjustable.
Same problem here...plus I can't figure how to get the thing open to fix it.
It sounds as if it is stapling twice and then will not turn lose of the paper. The trigger device does not appear to be adjustable. I think I will have to give up.
I was able to remove the bottom plate, but it only exposed the wiring and connectors. The top housing did not come off and I have searched for a way to remove the housing with no result. I do appreciate your determination.
