Question about SI-TEX GPS
Si Tex CVS - 106MKII fish
We bought a boat with a Si Tex CVS - 106MKII fish finder and we have no manual. We would like to purchase one. Please advise. Thanks. Barabara
Posted by barbdalebrow on
jimpa
Hi guys i need the manual guide for cvs-106mk2 in greek version....
Posted on Jan 06, 2014
5 Related Answers
coldandwet
SOURCE: SI-TEX MAX 10 NT
Do you still have this unit around? Can I have it?
Posted on Sep 08, 2008
Anonymous
  • 214 Answers
SOURCE: brought a boat with lowrance x24 no manual with it
Here's a link where you can download the manual..
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Good luck & have fun. If this helps you plz rate this 'fixya' for me. Thank you kindly.
Posted on Feb 11, 2009
Anonymous
  • 1111 Answers
SOURCE: I am having one heckuva
go to products then fishing buddy.
http://store.humminbird.com/csonar-csonarBuddy.html
Posted on Jun 17, 2009
Anonymous
  • 122 Answers
SOURCE: I bought a boat had a SI-TEX XJ-9 LoranC on it but
It does not matter since Loran-C has been phased out. Sorry but you should pickup a GPS. Good Luck
Posted on Jul 23, 2009
Anonymous
SOURCE: I just bought a used
need to dowload instructions for Bush CF04 Coffe Maker
Posted on Jun 20, 2011
I have a very old Si-tex pro II finder that im trying to get running can any give me a diagrame of how the wiring. the coulors of each wire does what? witch plug/wires runs to the tranducer??? Thanks Sam
Hello, Ticle33 did you ever get he hold of a wiring diagram for the si-tex profish II? I am in the same situation and cannot find one. Hope to hear from you. Thanks /Tom
1helpful
I recently bought a boat with this type depth finder on it. It was working fine until I was unable to get off a local beach that people commonly pull up on. The water ran out and the entire bottom was...
Hi, make sure that the bottom of the transducer is parallel to the bottom of the boat. It probably has been knocked upwards while on the beach. If not the transducer will need to be replaced. Hope this helps, regards Phil.
2answers
Want to know depth range just bought boat with this unit know nothing about it
with the correct transducer you can mark fish at 600 and bottom at 100 feet
Needing a uses manual for a si-tex CVS-209 please
Try to check from this link out:
http://www.si-tex.com/2009support.htm
There are manuals for GPS devices listed there.
Goodluck.
Jan 12, 2010 • GPS
1helpful
Lowrance LMS522c transducer
Probably not. Usually the transducer is made specifically for the head unit it is designed for. More often than not, transducers are not interchangeable, particularly across brands. Also, for best results, you really want to install the transducer that came with your new lowrance. That will give you the best results and sonar clarity.
Hope that helps!
Please rate my solution on FixYa!
Need info or a manual
I've found SI-TEX's support page: http://www.si-tex.com/html/support.html where they say this:
Printed copies of retired products and the manuals above are available for $15, if mailed within the United States.
E-mail or call us to request a printed version of a manual.
Their number is: (727) 576-5734
Oct 29, 2008 • Boating
1helpful
Si-tex cvs 106 mk11echosounder
To re-program the Si-tex CSV-106 depth sounder to feet/meters/fathoms: Push and hold down the MENU key while turning the unit on (POWER key) to enter a special menu. Release both keys after you hear two beeps, almost immediately. Use the LOWER ALARM key to select the desired unit for depth, then turn off the depth sounder. That's it, just turn on again to see the change.
There is also another menu (for testing sounder) available by pressing the MODE and turning on as above.
GPS Logo
Top SI-TEX GPS Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a SI-TEX GPS Expert? Answer questions, earn points and help others
