Your ink cartridge is low, empty or possibly clogged
First step is to see will if it print a test page
Go to Start, settings, printers. Right click on the printer, properties, print test page.
If that doesn't work there should be a head cleaning option in properties that will make it clean the print heads.
If there is still nothing after that then either it's badly clogged, low or out of ink, and needs to be replaced
This may help
Turn on the hot water until warm
Put about 1/2 inches of water in a cup
Put the print head portion (where the ink comes out) in for about a minute or two
This will help to dissolve the clogged print head
Dry off the cartridge using a soft tissue.
Re-insert the cartridge into the printer.
Run the normal cleaning software routine a few times
Still having Problem Then follow Us For
Brother Printer Support
It does print the whole page but leaves out even parts in the center....as an example...if I print a bank statement, it will print all the numbers but not the column with the description of where the check was written. It's very bizarre.
