Question about HP Compaq Presario V2000 Notebook
Can't boot up to CD
Every time I try to boot up to CD on my Presario V2000 it keeps trying to boot up to my lan, When not connected it goes to "Exititing PXE, but when it's plugged it it looks for media it can't find, regaurdless, I can't boot up to my XP home cd.
Posted by pecreacy on
  • pecreacy May 04, 2009
    I found the issue; First time I reinstalled because of 640 registry errors, I used the recovery partition, Hosed the whole system some how, and blue screaned(of death) so I took my old image file and burned it to a cd, but the cd wasn't saved as a bootable image, that was the problem, I can enter PC check and Linux partitions no problem. so that was my issue, Thanks though.
Anonymous
    Problem Solver:
  • 18 Answers
You need to go into bios by pressing F2 or delete at boot up. Once you are in setup you need to change the boot sequence to the cd drive as number 1 and the hard drive as number 2 then press F10 to save and exit. then reboot the computer and it will boot off the cd.
Hope this helps.
Posted on May 04, 2009
  • Anonymous May 04, 2009
    You need to get a program called UltraISO and you can put all the files into a real disk immage then use alchol 120% to burn the ISO to a CD.
    Give It a try It might Work.
    Good Luck
My V2000 won't boot. It starts to power up, beeps twice stops at the Compact sign in the middle and "press [esc] to change boot order, press [F10] to setup, press [F12] to boot from lan" at the bottom....
probably keyboard connector is loose so, no imput from keyboard is coming in so it halts bootup. please check the connector [opening of a computer is requied probably]
Oct 30, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 won't go past welcome screen
try to insteret you cd recovery from your laptop box...
if you cannot, restore your backed up data...
if you do not have any backed up data!!!!!!!!!!!!!!!!!!
DANGEROUS,,, you will have to insert windows xp cd installiation then click the button that says Repair e.g F'' F;;
Aug 27, 2009 | HP Compaq Presario V2000 Notebook
Problem with compaq presario 2500
hi
go to the Bios setup and set the first booting device as CD drive and it will check the CD first
cheers
pls rate if it was any help
Jul 05, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Compaq presario v2000 cant go online using the intergrated broadband connection both wireless & wired. The broadband adaptors are working properly and the wifi has allowed the antivirus to update, but not...
Have you tried to use a different browser to rule out IE (that has not been previously installed on PC)? Try Firefox (I prefer IE BTW), and if your internet starts working you know that it's your browser's. Also, you can check to make sure that there are no proxies setup in your IE. Click on Tools > Internet Options > Connection tab > LAN Settings (at the bottom) - once in LAN Settings, uncheck all the boxes.
Mar 31, 2009 | HP Compaq Presario V2000 Notebook
DVD drive keeps on opening when starting
If the boot priority in the BIOS setup screen is set to thr CD it  will open the cd door every time you boot looking for the BOOT cd.    It will not accept anything else, at that point except a boot cd since it hasn't found the operating system (windows) yet.    By "blue laptop" you mean "blue screen" DO a "Windows restore" or reinstall windows from the reinstall cd or Harddrive partision containing the restore files.
Jan 27, 2009 | HP Compaq Presario V2000 Notebook
V2000 does not boot from the CD
if you are trying to boot from a windows cd, the boot menu will be correct, but you need to press ENTER when prompted to boot from the windows cd, the fact that you have a dvd drive makes no difference, the only other problem maybe that if you are using vista the system cannot recognise the discs written format type
Aug 14, 2008 | HP Compaq Presario V2000 Notebook
Prosario V2000 boot problem
This means that there is some component was not fixed well.
this error means: " press esc to change boot order"
"press F10 for setup press F12 to boot from lan"
with 2 beeps " that the system cannot find hard drive:
fixed every thing: and try this. if prompted to go setup , continue and find "load bios setup default and then save and exit.
Jan 08, 2008 | HP Compaq Presario V2000 Notebook
Booting my system through LAN
you cannot do this as the lan boot up refers to a workstation and server type setup where the operating system back up is saved on to a server incase of a system crash; which will not apply to your pc.
Sep 13, 2007 | HP Compaq Presario V2000 Notebook
Reinstalling Windows on Presario V2000
Well, you can install XP as long as you have a CD and your laptop has a COA with a key. Hit delete, F2 or F10 to start the system in setup, change the order of boot devices to make the CD your primary boot device. Restart, boot into the CD and follow the prompts. After you complete your installation you can go to www.hp.com SUPPORT and DOWNLOADS and find whatever drivers you are missing. Take your time and you'll do fine.
Sep 08, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
151 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
