Cardo Systems Cardo Scala Rider G9 Powerset Logo
a
arjun belliappa Posted on Nov 16, 2013
Scala g9 is not pairing with my phone
My old phone was connected to the scala rider g 9 but my new phone will not discover the scala rider g9
My scala rider g4 detects iphone but does not pair
All I did was clear it from the phone and made sure I had a full charge on my scala. Then I just reconnected it. That was it. Once I had made sure I had the full charge that was it.. Done. Hope this helped. Regards, Denise
Charge light on scala q3 does not go off when charging
I am more familiar with the G4 and G9 models but usually when the charging light will not go out the battery is beginning to fail. I believe I read that these models contain the same battery as the original classic Ipod. They can be found on ebay or Amazon.
I have batteries for the G4 and G9 models. I can be reached at Chris at RoamingDZ dot com. or 478-227-9445
Not pairing with other devices
Have you turned blue tooth settings on your phone? Also you can pair your phone if the Bluetooth is working. Otherwuse you may be out of range. If that does not work have someone else try the bluetooth to eliminate the problem is with your phone.
Scala rider connects to phone 1 and phone 2 and after 10-15 seconds it shut down
give it back. I also have problems with my Scala rider Q1 system. I would not pay R 200 FOR THIS TYPE OF RECEPTION and i have payed R3000. Bad deal.
The scala rider Q G A won't pair with my I Phone it keeps saying swich your scala on
The scala rider Q G A won't pair with my I Phone 4S it keeps saying nothing
1helpful
Headsets won`t pair.
I am having the same problem. Did you ever find the solution?
4helpful
What is the passcode for the Scala LX700 bluetooth?
Four zeros is the PIN you want to use for pairing
  • 0000
That's also the default code for a majority of bluetooth headsets.
Here is the entire pairing process broken down:
1. Turn on your phone and make sure that its Bluetooth function is activated.
2. While the Headset is turned off, press the Wheel inwards for at least
8 seconds. The Status Light will begin rapidly alternating red and blue,
indicating that the Headset is in Pairing mode.
3. Using your phone, search for Bluetooth devices by following the
phone’s instructions.
4. After a few seconds the phone will list the scala-700LX as a “discovered
device”. Select it and follow your phone’s instructions to accept the pairing.
5. When prompted, enter 0000 (four zeros) as your PIN or passkey.
6. Your phone will confirm that Pairing was successful and the Headset’s
Status Light will begin flashing slowly in blue.
Top Cardo Systems Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Cardo Systems Radio Communication Expert? Answer questions, earn points and help others
