SOURCE: WHERE ARE THE FUSES LOCATED FOR AKAI PT5598HDI 55" PROJECTION TV?
replace your convergence IC chips it is not a fuse problem.
SOURCE: AKAI PT5598HDI 55 Where is fuse located
This problem is beyond a blown fuse most likely. The fuses for the unit are located on the circuit boards and the back will need to be removed to access them. This problem could be due to a missing voltage that is used to turn on the picture section of the electronics. I would search for a used unit on ebay or parts on ebay and swap out the boards. The board swap is not too complex but voltages are dangerous within the set and service by a qualified electronics technician is recommended on this unit. Thanks and good luck. Dan
SOURCE: AKAI PT5598HDI Colors out of line.
http://www.fixya.com/support/t1663670-akai_samsung_pt4299hd_convergence Adjust the convergence manually. It's a pain and takes alot of patience. The diagram for the remote buttons helps a lot. If it won't adjust you'll have to replace a part inside the tv. Good luck! Hopefully it'll adjust.
