Question about Lexar FireFly 2GB USB 2.0 JumpDrive
Lexar 8GB FireFly Stopped working
I used the Lexar FireFly flash drive early in the morning when I went back to retrieve another file, it was no longer recognized by the computer. I tried loading it on several other machines but it's like the flash drive was not plugged in at all.
Posted by mboulrisse on
2 Related Answers
laikexpert
laikexpert
  • 281 Answers
SOURCE: Lexar firefly 1GB Jump Drive - Can't copy files to jump drive
1.
Update Your Windows Operating System.
2.
Check your computer.
with antivirus and antispyware program.
3.
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
3.a) Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
3.b) Format pendrive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 08, 2010
panacam
  • 12 Answers
SOURCE: Lexar 8GB wont work. when i insert it, it shows up
Some computers will not support a large 8GB stick. The best some will do is 2GB, If you are running a computer pre-2001, you may not be able to use the 8GB stick (I have the same problem with my desktop PC). It just is not supported!
Posted on Oct 05, 2010
Lexar 8GB wont work. when i insert it, it shows up on my computer as connected but then when i click on the lexar icon to view my files on it, it doesn't open, the message: 'please insert disk into drive...
Oct 05, 2010 | Lexar Professional High-Speed 2GB Secure...
My 2GB Lexar flash drive has stopped working. It
A flash card wears out every single time you use it. Yours has just reached its end of life - it's dead. Replace it.
May 06, 2010 | Lexar Professional High-Speed 2GB Secure...
Storage issue LEXAR Firefly 4GB
Empty your "Recycle Bin", to permanently detect some "hidden" files on the JumpDrive.
If necessary, try a "quick-Format" to reformat the drive, deleting all "hidden" files.
Mar 03, 2010 | Lexar FireFly 2GB USB 2.0 JumpDrive
I deleted all the viewable files and folders on my lexar firefly jumpdrive, but it says that i still have almost all my memory used up. how can I clear it?
You may have hidden or locked files. If the files are locked, you'll see an icon to unlock them when you open the JumpDrive in Windows Explorer. If the files are hidden, try and show them: Tools-->Folder Options-->View--> Left Click "show hidden files and folders" Good Luck!
Jan 05, 2010 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
I dont know how to save a writing piece from the word pad onto the lexar firefly
Open Wordpad, click File-->Save As; type in your desired name for the file and click the pull down arrow near "Save in:". Select the appropriate Drive (G/D,E or whatever) that is your Firefly. Click save. The file should now be saved as a Rich Text Formatted document on your Firefly. You can save it as a Text Document as well under the "Save as type:" option. Good Luck!
Oct 20, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Hi there, I'm having problems opening the files on Lexar 2GB JumpDrive FireFly it just says not formatted do you want to format? Please help I have precious photos etc. Thanks
If it says that the files are probably gone, sorry. Try using it on a different system, if it says the same thing they are definitely gone. Good luck I hope it works on a different system.
Aug 14, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
Flash drive repair
It sounds like your media is malfunctioning (electronics).
For this type of problem, we offer a data recovery service.
You simply have to send your media to us.
Our technicians will recover your files on CDs and return everything
within 48h. You just need to send us your Lexar with this form:
http://www.lc-tech.com/documents/LC_Technology_Data_Recovery_Service-SD-Eric.pdf
There is a charge for this service, but ONLY if we
are successful. The pricing is on the form. Please note
that the chances of recovery are around 90%.
Eric Beaudoin
[email protected]
1-866-603-2195 ext 103
LC Technology International
Mar 24, 2009 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Please show me step by step on using the Lexar 2GB JumpDrive FireFly flash drive. I have an HP computer. I need to back up many photos. I will buy more of the same flash drives if I learn how to use them....
What operating system are you using? Should work with XP and Vista. Go to windows explorer and click on C drive, click photos folder, select required photo, click and drag icon to the Firefly icon and release mouse button. File should be copied to jump drive.
Feb 18, 2009 | Lexar FireFly 2GB USB 2.0 JumpDrive
1.
2.
3.
Dec 28, 2008 | Lexar FireFly 1GB USB 2.0 JumpDrive - Blue
Lexar FireFly 2GB USB 2.0 JumpDrive Logo
416 people viewed this question
Top Lexar Electronics - Others Experts
Ekse
Lawrence Oravetz
Are you a Lexar Electronics - Other Expert? Answer questions, earn points and help others
