Question about Motorola Televison & Video
Rebooted the fios stb and now I see 8888 when the stb tries to reboot.
1 Related Answer
Anonymous
  • 11 Answers
SOURCE: Need a code that works with the Verizon FIOS DVR
Try 0000000000
Posted on Jul 21, 2009
How to get volume control on my FIOS remote with Samsung TV?
Re: How can I get the volume control on my FiOS remote to change the volume on my AV receiver?
  1. Hold down the STB button on your remote control, and press OK. Release both buttons.
  2. Key in 9-5-5.
  3. Press the device button whose volume you want to control by default (in this case, AUX).
  4. Press OK.
https://forums.verizon.com/t5/Fios-TV-Technical-Assistance/How-can-I-get-the-volume-control-on-my-FiOS-remote-to-change-the/td-p/246987
Sony bravia volume control not working with FIOS STB
found the problem after reading a post on this site. Last thing I used was DVD player so disconnected DVD Sony player, followed the factory reset instructions and now the volume works normally! It was the DVD player. Thank you so much for the info and lead. The problem is DVD not TV,
Jul 20, 2014
1helpful
I need the remote code for the insignia sound bar to use with my verizon fios remote control
Jeff Phillips What I did was connec the soundbar audio directly to the Verizon STB audio out and changed the remote to control the STB volume instead of the TV. Then I plugged the soundbar into the switched outlet on the back of the verizon STB.
2helpful
My box randomly turns off and flashes 8888.
same problem here. stb turns off randomly and displays 8888 and locks itself. usually if your press the select button 4 times and turn the stb on again it works but you will have to wait 20 min for it to get the channels or dvr. still no permanent solution though
2helpful
Having problem to use the Verizon FIOS Remote control to control the volume of my Sceptre X42 LCD TV. The FIOS remote is able to turn On/Off the TV though. Any idea what is wrong with this?
program the remote to control tv volume by 1. Press and hold the STB key. 2. While holding down the STB key, press OK. 3. Release both keys. The Device Keys will blink twice. 4. Press 9 - 5 - 5. The STB key will blink twice. 5. Press TV. The TV key will blink 3 times to indicate success in programming. try the remote after that . if the volume still doesn't work check to see if there is another code that also works with your TV. (on my Sony TV one code works everything while another code only turns it on and off. for my Epson S3 the remote will not work with it at all.) here is the manual for the remote: http://www22.verizon.com/NROneRetail/NR/rdonlyres/2DEF67C9-87F0-4B46-B1BD-A40472BC281A/0/PhilipsRC144RemoteControlUserGuide.pdf
I own a Go-Video DVD-VCR Player, Model DV3140. I recently switched to Verizon service and find that I can no longer olay my DVDs/VCRs with the Fios System. Can you assist me in how to program my player...
Hi
You can reprogram it by following these instructions--
Power turns on or off both your STB and TV when you are in STB mode. (If you have a DVR STB, the DVR will continue to record scheduled programs when off.) However, you can reprogram how the Power Key works. If you want the Power Key to control multiple devices at once --
4. Press 9 - 7 - 7. The STB key will blink twice.
5. One after the other, press each Device Key you want the Power Key to control, in the order you want them to turn on or off. Each selected device Key will blink twice after it is pressed.
6. Press OK when done. The STB key will blink three times to indicate success in programming.
For example, to program the Power Key to turn on or off your TV, AUX and
STB, in that order with one press of the Power Key, press [STB+OK], [9-7-7],
[TV], [AUX], [STB], [OK].
These are the codes for GO Video DVD Player--
Go Video 0771, 0768, 0810, 0896, 1071, 1102, 1185, 1757
You can view/download the manual for the fios from this link--
Verizon fios remote programming
You can visit this link for more information--
Verizon FiOS Troubleshooting
If you want to doanload the user manual for your verizon set top box you can get it from here
Please do accept this solution and revert for further assistance.
Thanks
Rylee
1helpful
Using FIOS HD DRV STB with a VCR
Okay let me make sure I understand.. Looking at the back of your STB and VCR do you see an (IN) and (OUT) coxial connection?
If so, you can use the coxial connections to obtain your desired results.
I hope this solution is helpful. Please remember to rate thsi solution.
4answers
My Samsung LN40A530 only produces a blank blue screen whenever I try to use an HDMI input source. Audio seem to come through fine but not the video. Other, non-HDMI video inputs work fine. I've tried...
We are having the same problem. We have 2 DVD players with up-converter to 1080i and 1080p. Both DVD work fine (one Sony and one Samsung) with our Samsung LN-T4053H upstairs, never intermittent.
LN40A530 downstairs is having "Searching for Signal" problem. Took it back to Sears got a new one, problem followed. Something is wrong with this LN40A530. Perhaps firmware update is needed.
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Televison & Video Logo
Top Motorola Televison & Video Experts
Joaquim Martins
ray gallant
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
