My digital tv aerial has been pulled out from the tv and i want to connect the set top box to allow me to watch the tv again
Ok, I am confused. How old is the TV? If new, hook the ariel directly into the tuner on the TV. The ATSM tuner in auto configure will identify and setup the channels with no need for a set top box. On old TV using an Analog Tuner will need a box. Antenna in goes to the antenna, antenna out goes to the F connector on the TV. Should be one coax connector on the TV. That is an F connector. Set the TV to channel 3 or 4 depending on what the switch is set on the back of the set top box.
Testimonial: "the digital tv is relaitely newbut the antenna connection has been pulled out so the connection no longer works - i was told if i connect a set top box this will work as the aerial but i cannot tune it as obviously i am connecting it wrong ?????"
