Question about Gateway GTW-P42M303 42 in. Plasma Television
Gateway plasma yellow screen and it pulses p42m303
3 Related Answers
Anonymous
SOURCE: gateway 42 plasma p42m303 parts
There is an image board on sale on ebay you may want to check this out.
Posted on Sep 12, 2008
Anonymous
SOURCE: hi i have a gateway
probably the tv card is not working, a flat capacitor is the problem you have to change it
Posted on Apr 14, 2009
Matthew deSilva
  • 375 Answers
SOURCE: I was working on my
Hi there, hopefully a nice easy fix, have you checked the fuse in the plug?
hope this helps
Posted on May 07, 2011
I have gateway plasma tv srs bbc 50 " get verry hot in the exauste and in the sreen is it normal? think's
Yes,it's normal, a plasma uses a lot of power (over 300W) so it generates a lot of heat - especially the screen.Remember, plasma is an overheated gas so a large screen contains a very large amount of a very hot gas.
Tv black with red green yellow dots but when warms up it alright
Try backstepping the set resolution on your TV to see if that cures it.
Please rate my help++++Thanks for using FIXYA
Gateway 42" plasma has sound only, no picture. 6 years old
Gateway 50" plasma tv #7005406 runs only in black and white after power outage. Menu screen still in color.
I have a Gateway gtw-p42m303 powers up to the warm up screen then light switches from green to standby orange. smells hot could be a power supply or capacitor?
Most likely a Y sustain module failure. Gateway does not make a set, so I would need a part number off of the board in order to give you an exact price of the part. Usually they're around $300.00
1helpful
Gateway gtw p42m303 promblem need advice
I think you need a control PCB.
If the Set has an LG Screen, which I think it does, it is going to be a PDP42X2.
They commonly produce vertical Red and or Yellow lines that come and go.
6871QCH060Q is the boards part number.
You should just check it is an LG PDP42X2 by peering through the holes in the top, use a flashlight, there are some labels along the inside at the top.
One will have the Screen number on it.. LG PDP42X2 or PDP42X2A.
Gateway 42 plasma p42m303 parts
Gateway TV
I have had the same problem on my gateway plasma for a year now. My 2nd TV just started to show similar defects on the screen. I can never get a straight answer as to what causes this problem yet it is a very common defect on these tv models (gateway) most accurate answer I got from gateway was that it is better to buy a new one.
Gateway GTW-P42M303 42 in. Plasma Television Logo
Top Gateway Televison & Video Experts
Falling star
Ekse
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
