Measuring Tools & Sensors Logo
A
Anonymous Posted on Nov 16, 2013
Changed batteries can not reset - La Crosse Technology Measuring Tools & Sensors
2004 Mini Cooper S. I have changed the battery, the alternator and the belt. The battery light is not on except when I crank it does it need to be reset? Can I reset it myself? Please help.
Number 1 tip when changing batteries is to maintain 12 volts to the battery connectors during the change over. You can do this with a battery minder, a battery charger, jump leads or just a couple of lengths of wire.
You need to reset the security system immobilizer.
https://www.google.com/search?q=2004+Mini+Cooper+S+reset+security
1helpful
2answers
Do i need to power down to change the back up battery
If this is ordinary residential timer, you can replace battery without changing anything.
Just replace battery.
Most timers will hold some or part of the memory during battery changeover... frequently losing no programming if battery change is done quickly, and battery was not completely depleted, and timer is still functional.
If timer function is not restored after battery change, reset timer fully and then reprogram.
If battery change and reset does not work, then timer is probably gone bad.
Most modern timers have reset button, but some require a 2-button sequence to reset.
Other modern timers have a 'battery' but the battery is built into the circuit board and thus not replaceable ... it is rechargeable, like a capacitor ... but when it fails .. the timer needs to be replaced.
Timers with replaceable batteries are generally not functional after exposure to freezing temperatures for several day, but the non-replaceable type generally have wider tolerance for temperature variation.
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/Programmable.html
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Resetting bmw x5 after changing battery
use a code reader to reset the CPU
Reset after battery replacement
What battery and what are you reseting?? if you changed the actual battery that cranks the car and now the VDC light is on, you will have to go to NISSAN dealer and have the "steering angle sensor" re-calibrated. If you changed your battery in the remote, then there is no reset. it should work just fine after the battery is replaced, unless the remote is NG.
When i change the airag in my truck do i have to have the computer reset or can i simply unhook the battery change the airbag and then hook the battery back up
Disconnecting the battery resets the computor anyway, so you don't have to have it reset.
Also pull the fuse for the airbag.
Changing the battery resets my date. is there another battery
your camera doesn't have internal battery so everytime you change the battery it will ask you to set the date...
Wont power up, blue lights stay on have changed out the batteries
try resetting the remote and the console. in the console you open front panel and their is a red reset button press this firmly then remove batteries from back of remote press the reset on the console again. Then replace the batteries press the red reset on the console a third time and then push the red reset button on the back of the wii remote this should take care jof your problem.
5helpful
Battery change and then reset
If you open already the watch,and you want to take the old battery,there is a clip that's lock the battery twist that lock.then the battery comes out and replaced with a new one. If you have already put the battery and no display you must reset it by shorting battery connection,in the plate there is arrow guide to the hole where you put your tweezers to short the connection.then the display appears 8888,that is already resetted take the tweezers..
click below for video guide;
G-ShockBattery Change Tutorial
hope this may help
DON'T FORGET TO RATE
Regards,
VOTIT
2answers
Hard reset screen appears whenever i change the main battery
Your pda has a built in battery.The inbuilt one has lost its charge. To keep it from reseting to its original factory settings. You need to keep the main battery(the one you charge up) regularly charged.
4helpful
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Top La Crosse Technology Measuring Tools & Sensors Experts
Ngoro
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
