Brand new copier out of box. Only in copy mode there are equally spaced thin lines across the page, not in direction of paper feed. Internal prints look fine. Static on CCD chip?
SOURCE: Horizontal White Banding
Most likely cause is that a roller has degraded during storeage. Measure the distance from the centre of the first band to the second and from the center of the second band to the third. If this dimesion is fairly constant you can work out exactly which roller is causing the problem. The most likely culprit will be the Photo Conductor Unit. This will give a large dimension - (approx the 29cm??) A service manual should give you the dimensions (circumferences) of the rollers within the machine. If you have a spare pcu around, put it in and see if it makes ANY difference.
SOURCE: Can't get the copier to scan only 8.5*11 area on glass
Set your original settings to the actual size.
You are using the auto recognition feature which is over-ridden when you specify the size manually.
It will try to match it to the nearest size it "knows". That is why the stamp is detecting so large.
SOURCE: when I try to print multiple copies from a file on
Change the port on the print driver to raw and check the print immediately button.
i am having the same issue ..what did you do ? please help
