Russell Hobbs RHOK3123 Cordless Electric Kettle Logo
Question about Russell Hobbs RHOK3123 Cordless Electric Kettle
Russell hobbs kettle base won't turn on
Won't turn on.
Haggis McBagpipes
    New Friend:
    Problem Solver:
  • 8 Answers
Just pulled apart a Russell Hobbs Whisper Model 3090 cordless kettle which i have been using every day for a few years.
It was intermittent turning on.
I fixed that problem by bending one of the switch contacts on the inside just a little as it had burned away slightly and was only making contact sometimes.
When I put the bottom back on and tested it I noticed that the water had an electrical smell which was strange as I had never noticed it before.
I then pulled it apart again and noticed that one of the main wires from the switch to the element had the insulation melting so I replaced that wire and now there is no smell in the water.
To confirm the smell I held the old wire and insulation on a flame and that is definitely what the smell was. The smell was travelling UP the tube which takes steam down to the bimetallic strip to turn the kettle off and was contaminating the water in the kettle.
Posted on Nov 19, 2018
5 Related Answers
Ian
  • 51 Answers
SOURCE: russell hobbs wisper quiet kettle
If it leaks now, it will in 2 weeks.....take it back.
Posted on Jul 25, 2007
Anonymous
  • 44 Answers
SOURCE: kettle will not heat. Russell Hobbs corded
Check mains fuse, if ok check for voltage at kettle , with multi meter, not phase tester as these can be faulty, if you have power and no heat then it has to be the switch or the element, check and replace same. if your unsure have an electrician do it for you
Posted on May 01, 2009
caroldon
  • 17130 Answers
SOURCE: Have you got a manual
Check if this link helps:
www.kitchen.manualsonline.com/ex/product/headline/m/???russell_???hobbs/d/slow_cooker/p/???13792
Posted on Sep 28, 2010
richroth
Richard Roth
  • 9472 Answers
SOURCE: I have a Russel Hobbs
You will need to replace the heating element on the kettle. Here is a link to order the part.
Posted on Sep 20, 2011
ebiau
Ebiau Daniel
  • 107 Answers
SOURCE: russell hobbs kettle
You will need to first shock that kettle first bold hot water then remove it and replace with very cold or ice water. The smell like plastic is brought by the Plastic which over heats and somehow weakens to a point of melting thus releasing a smell into your water, Shocking the kettle would help if not then you will need to buy another kettle as that one might not be original or just wasn't tested for regularities and standards.
Posted on Sep 21, 2012
1helpful
RUSSELL HOBBS 18941 KETTLE has slow leak from the bottom of kettle.
They are pretty much a disposable item when they fail. You could try repairing with epoxy putty. Some bases can be screwed a bit tighter.
https://www.google.com/search?q=KETTLE+MOD+18941
Manual
RUSSELL HOBBS 18941
and regarding kettle leaks
https://www.google.com/search?q=KETTLE+MOD+18941+leak+at+base
Russell Hobbs kettle 20191. How to get to wiring in base unit of it?
Turn it over and look for screws under the feet. In reality, modern kettles are a disposable commodity.
I have a russell hobbs 4110 kettle l need the part at the end of the cord that goes into the kettle from the base can you help
Careful russell-hobbs.com appears to *not* be connected with the manufacturer Russel Hobbs (which is RussellHobbs.com).
Also, the phone number tries to draw you into a scam gift card
How to enter code
instructions - Russell Hobbs
uk.russellhobbs.com/pdf/14590_stylis_black_kettle.pdf
2 Don't put the kettle, stand, cable, or plug in liquid. ... 4 Don't open the lid while the water is heating. 5 Don't ... 8 Put the kettle on the stand - take care not to spill. .... To avoid environmental and health problems due to hazardous substances in electricaland electronic goods, appliances marked with this symbol mustn't be.Missing: code
Kettles - Russell Hobbs
en.russellhobbs.com > Our Products
Over the decades, Russell Hobbs has been at the forefront of quenching our national thirst for hot beverages with fast, easy to use, great looking electric kettles.Missing: open ā€Žquestion ā€Ženter ā€Žcode
Russell Hobbs KE9000S Electric Kettle, Stainless Steel
www.amazon.com/Russell-Hobbs...Electric.../B00A15...
Amazon.com, Inc.Amazon.com: Russell Hobbs KE9000S Electric Kettle, Stainless Steel: Electric ...
Hello I need a water filter for our Russell Hobbs kettle 13355 model. Is it possoble to buy on line? Thanks for geting back to me.Bridget Jorro [email protected]
Hi Bridget,
Here are a couple of sites where you can buy Russell Hobbs parts: http://www.viewpointdirect.co.uk/russell-hobbs-kettle-filter---for-13355-1764-p.asp http://www.twenga.co.uk/dir-Appliances,Appliance-spare-parts-458 Or you can contact them: [email protected]
Best, S
Top Russell Hobbs Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
ADMIN Andrew
ADMIN Andrew
Tom Chichester
Are you a Russell Hobbs Kitchen Appliances - Other Expert? Answer questions, earn points and help others
