SOURCE: Remote Control Extender from Radio Shack
To determine if your PC will simply not connect or if really your wireless AP/Router, please download NetStumbler,
install and run. The software will determine if there is an AP within
your immediate area (including yours/high signal strength), if there is
& it is yours, then it is configuration problem, it none or some
but weak (low signal/not yours) then it is a hardware problem and would
most probably require replacement. Most of the time, the cost/time of
repair would make the purchase of a new one more reasonable. If your
Wireless Ap/Router was detected by NetStumbler, then perhaps what you
need is to re-configure your system/set-up again.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional; information.
Good luck and kind regards.
SOURCE: Need radio shack remote control code.
It will be one of these codes.
Orion 0236, 0463, 1463
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
you can go to the manual direct at. Good luck
SOURCE: remote control Radio Shack 15-2147 Toshiba HDTV DVD - HOW TO?
The code for a Radio Shack remote control for a Toshiba TV with a DVD built in is: 1945! It worked for me easily! Good luck.
SOURCE: need remote control codes for a Radio Shack 3 n 1
Try this :) click the download now and allow the download. It is PDF format.
SOURCE: Program Radio Shack 15 2142 remote for converter box
only if the converter box is using older codes that were in use when the remote was made.
