Question about AEG 7.59 cu. ft. / 215 liter Upright Freezer A75238GA
Upright freezer not cooling adequately
AEG 'Arctis' upright freezer (unfortunately it's an all singing, all dancing variety with no instruction book) frost free. Display reads -18 degrees but no way is it that cold. I've defrosted it (if you see what I mean) but there's nothing to defrost! Any help will be much appreciated!
Posted by jandjbower on
Bruce McLeod
  • 67 Answers
Go to there website and see if you can find your model. You can also contact them from there.
http://www.aeg-electrolux.co.uk/node145.asp?CategoryID=2595
Also get yourself a stand alone fridge and freezer thermometer - leave it in for an hour -that will establish what the temperature really is which will help in diagnosing the cause.
Also trying unplugging it for 15 minutes so the display board loses power - then plug it back in - sometimes that will reset it.
Posted on May 04, 2009
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Jul 17, 2016 | AEG 10.35 cu. ft. / 293 liter Upright...
Why is the temperature fluctuating.
Service engeener always checks the average temperature inside freezer or refrigerator compartment. When you turn on freezer, the compressor starts to circulate gas through the system and the temperature in the freezer is decreasing (go to minus). When inside of the freezer reaches the set temperature the compressor is switched off and temperature will increasing. What will be the difference of inside temperature depends on the type of refrigerator and type of thermostat or sensor and moves to max. 8-9 degrees. With the advent of new "No Frost" refrigerator, this difference was reduced to only a few degrees Celsius, thanks to the fan inside the refrigerator and NTC sensor.
So 29 + 14 = 43; 43/2 = 21.5 which means that your average temperature of -21.5 which is not too much deviation from the set temperature of -18 and I think that is ok.
Dado
Jun 13, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Orange light is on instead of green light on freezer what does this mean
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Left my upright freezer open a crack and now the
With the door left open moisture would get into the unit behind the walls and into the duct work. The only way to fix this right is to unload it and let it unthaw for a day or so open. Once it is all defrosted and restarted it should be fine again.
May 09, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Orange light is on instead of green in the freezer does this mean anything?
no. the orange light is the temperature light and the green light is the mains light.
Apr 06, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
Hi Arctis frost free freezer,almost 4 years old. Yesterday morning I noticed that the temperature had risen to 15 and today it is at 12. The motor is still running. Any advice would be appreciated. Thanks...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Mar 09, 2010 | AEG 10.35 cu. ft. / 293 liter Upright...
AEG 7.59 cu. ft. / 215 liter Upright Freezer A75238GA Logo
1,050 people viewed this question
Top AEG Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an AEG Freezer Expert? Answer questions, earn points and help others
