Question about Brother IntelliFax-2820 Laser Fax
In brother fax 2820 how to change language from german to english
5 Suggested Answers
checkitright
CheckitRight
  • 1363 Answers
SOURCE: brother FAX-2820
check the RX settings
http://www.retrevo.com/support/Brother-FAX-2820-Multifunction-Printers-manual/id/386bh831/t/2/
Posted on Aug 21, 2008
Anonymous
  • 25 Answers
SOURCE: FAX SAYS TO CHANGE THE DRUM SOON
Open the front couver as if you are about to change the drum unit. With the couver still open, press the options button for a while and in the display will apear a message asking if you want to change the drum unit. Choise the yes option and close the front couver. GOOD LUCK.
Posted on Nov 13, 2008
Ray M.
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
Anonymous
  • 37 Answers
SOURCE: Time Change on Brother 2820
1.Press menu
2.Press 0
3.Press 2
4.Enter the last two digits of the year on the
dial pad, and then press Set.
5.Enter the two digits for the month on the dial
6.Enter the two digits for the day on the dial
7.Enter the time in 24-hour format on the dial
8.Press Stop/Exit.
Posted on Mar 02, 2009
Anonymous
SOURCE: need drivers for Brother fax 2820
Need drivers for Brother fax 2820
Posted on May 03, 2009
Change language i have brother mfc 9420cn in german language.need to change into english language. thanks
http://download.brother.com/welcome/doc002005/MFC-9420CN_UsaEngQsg_B.pdf
page 13 of pdf file
page 11 of document
Press Menu/Set.
2 Press 0.
3 Press 0.
4 Select your language (English or French) by using up or down arrows
press stop / exit
Jul 06, 2018 | Brother Office Equipment & Supplies
How do i change language from german to english?
driver
http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=mfcj4410dw_us_eu_as
Jul 14, 2015 | Brother MFC-J4410dw All-In-One Color...
GERMAN TO ENGLISH ON MFC
Hello, you can try this simple steps configure your language in any language you want; english, german or japanese or even more! And this is the steps, kindly follow it thoroughly to changed it with ease;
1. Open your phone.
2. Tap Menu.
3. Tap Configure or Settings. (a wrench icon)
4. Tap Phone. (a phone icon)
5. Tap Language Settings.
6. Tap Phone Language.
7. Tap the language you want.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
Feb 04, 2014 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Select language
go to initial set up and choose local language, then check the English lalanguage. if no English then you have to update the firmware.
Apr 19, 2013 | Brother Office Equipment & Supplies
I need the Drivers for the 2820
You can download the installation driver and software from manufacturer's site by clicking this link
On the page which opens:
  • Select the operating system of your computer (Windows Xp/ Vista..) from the drop-down list
  • Select the Language (English) and click the Search button
  • Download and install the drivers and software from the next page which opens.
Hope this solves your problem. Thanks for using FixYa.
Aug 27, 2010 | Brother IntelliFax-2820 Laser Fax
Brought a used 2820 and it didnt come with disk to install wht do i do
You can download the installation drivers and software from manufacturer's site by clicking this link
  • On the page which opens:
  • 1) select the operating system of your computer (Windows Xp/ Vista..),
  • 2) Then select the language (English) and click on "Search" button.
  • Download the drivers and software from the next page which opens.
Apr 21, 2010 | Brother IntelliFax-2820 Laser Fax
Change LCD language to English on Brother MFC-3240C
Gud Day!
Power on your printer. Press the menu of your printer then sect the arrow down or up to select the language menu. press ok if u have seen language then go to option select from german to english.
Please rate the solution after you have tried it so that I can assess you more on this problem.
Jonags
Dec 11, 2008 | Brother MFC-3240C All-In-One InkJet...
How do i change the language?
I have Brother DCP-130C all in one Printer.
When I installed the software I chose English as the language, but when i am scanning & when i go into printing preferences it seems to be in German. I un-installed & re-installed but still not in English.
Any ideas how I can change the language to english please?
Mar 31, 2008 | Brother DCP 130C All-In-One InkJet Printer
My fax instructions are in german. I need the english version
Thanks for getting back so quickly- I have already solved the problem so thanks anyway! I just had to install it with the CD. and followed the prompts . It was all installed in english. :-)
Mar 10, 2008 | Lexmark X1240 All-In-One InkJet Printer
Brother IntelliFax-2820 Laser Fax Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
