I want to know how to change the lcd screen on lg voyager Vx 10000... Thanks !
THIS is what everybody else leaves out!!! first open ur phone and there are four sticker pads in the corner, use something with a sharp point to remove. Then use a phillips screw driver to remove the screws. the top with now come off, next there is a ribbon cable from the touch screen to the screen itself, On the connector there is a small plastic lever u will need to flip up in order to release the cable. Use a solder iron to remove the wires and it helps to write down on a paper where they go! do NOT LEAVE THE IRON ON THE WIRES TOO LONG!!!!! just enough to melt the solder and remove the wire, same for putting the new ones on! Next carefully remove the screen, it is held in place by sticky tape, be careful not to crack the cover, just be patience and do it slow! and put the new screen in in reverse order!!!! hope this helps!
Tallcool1
I broke the front screen also. the touch membrane is called the digitizer. the LG Voyager front screen is also the back screen. all one unit. I found one on ebay 50 bucks. came from hong kong. the replacement screen came with plastic help tools to get the phone apart. you will have to soldier the speakers and the microphone onto new screen. it took me about an hour. more difficult to put back together than take apart. it was worth it.
