Question about Scag SFZ61-730FS Freedom Z Zero Turn
Scagg freedom slowed down and will not drive
Belts are screaming when i drive forward or reverse, now it has no power for drive
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
Is this problem on both side are just one side?
Posted on Oct 19, 2016
6ya staff
SOURCE:
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
Jun 20, 2013 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Hi. I have an Alko T18-102HD ride on lawn mower that is starting to go very slow in reverse and forward. It gets to the point of slowing to a stop when reversing up a slope. I fitted a new drive belt...
I had the same problem with my Alko going slow in forward and reverse. Believe it or not the problem is caused by a build up of grass cuttings around the hydro clutch mechanism. If you follow the mechanism from the foot pedal you will probably find the actuator is being prevented from engaging by a build up of old grass. Clean it out and you should find it restores normal operation. This has happened to me a few times so now I blow out the grass on a regular basis with an air compressor which stops me having any problems. It also stops a hefty bill from the service dealer :-)
Jan 14, 2011 | Garden
Drive belt slipping, how to adjust
Where the lever mechanism for forward and reverse works down close to the engine mine has a bolt that you loosen and adjust the slide up and down to allow for more movement of the housing.
May 15, 2010 | Garden
No power when drive is engaged
Hi
Check your drive belt and the tensioner pulley that holds tension on the drive belt. Its possible for the tensioner pulley to be sticking and not putting enough pressure on the drive belt causing it to slip.
Grab hold of that tensioner pully and make sure it moves in and out freely against the drive belt.
Nov 25, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Scag SFZ61-730FS Freedom Z Zero Turn Logo
144 people viewed this question
Top Scag Garden Experts
Dennis
ray gallant
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Scag Garden Expert? Answer questions, earn points and help others
