On the HDMI setting, I cannot adjust the picture settings even on the custom setting. Half of the options are skipped over like color, sharpness, color enhancement, etc. The options seem to be adjustable when on a tv setting. Is there any way to change these on a computer setting with an HDMI cable?
On the computer itself is where you would change the video resolution and additional settings
Your graphics card if Nvidia or ATI should have it's own display properties, settings.
Testimonial: "I have the settings as I want them on the computer, rather, I would like to remove the color enhancement on the monitor itself because it ruins certain colors. I was wondering if there was a way to do so on the custom setting on HDMI, as it won't let me change those and skips the selector over the options if I were to try to."
SOURCE: Edge Enhancement Option Disabled...
edge enhancement option i think would be enabled if you are in dynamic or movie mode. What it does is to enhance the contrast of the edges of 2 different colors.
I have the LA32S8, similar specs but only 7000:1 CONTRAST ratio. when playing dvd, i set it to movie mode. Settings vary on different tv and player. you can adjust first the backlight, then brightness then contrast, color and sharpness. the brightness you adjust by choosing the level that shows enough details on dark scenes. adjust if its too dark not to see the details of the scene. contrast, you can set by distiguishing vivid colors of the picture, dont put too much contrast as your picture would look flat. it should have a 3d look, same also with sharpness, you can experiment on the face of a person to show details on the edges.
color you set just enough to make it accurate on color reproduction.
My settings for movie are
contrast 92
brightness 49
sharpness 23
color 57
tint g48 r52
backlight 7
tone warm1
digital NR off
black adjust high
dynamic ocntrast high
gamma +2
edge enhancement on
color space auto
SOURCE: The color on our lg 32pc5rv is too green and we cannot change it
you will need to check the componant cables on the tv, usually if the pic looks green, and wont adjust, the red componant plug has worked its way out, check it on the tv, and on the box, hope this helps
SOURCE: Vizio Model#:L37HDTV10A
Is the HDMI port 2 work? Try to turn it off and turn it back on. If it is still not working then the HDMI ports have gone bad. You will need to replace the main board.
SOURCE: Vizio LCD Green Pixels
Our Vizio started doing the same thing after only three weeks, except it was also showing green pixel when we watched DVDs. After checking this site and others and trying all the "tweaking" advised, I finally called Vizio's customer support. They were extremely polite and tried to help over the phone, but had to send someone to the house to make the repair (anything 40 inches or larger earns a house call). The tech arrived on time and was extremely professional and pleasant -- he had to replace the daughter board and LVDS cables. So far, so good.
SOURCE: TV suddenly lost the ability to project red
Reset the colors setting back to factory original setting.Should have all colors back to original.Not than ur main tuner signal board is dead,must replaced.
