Question about Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
Replace bulb whirpool model GB2SHDXTQ01 - Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
OUR WHIRLPOOL/CABRIO MODEL WTW6600SW2 IS FLASHING F1. WHAT IS PROBLEM?
Lool on this site for F1 fault. Apparently a very known problem, seems with control pcb. I called Whirpool today on a machine purchased in 4/07 with a 4 year extended warrenty from Lowes, and they didn't even question it. Said a repairman would be out to replace part and parts and labor are covered by Whirpool. Call them at their 1800 #, Mention it's the infamous F1 fault, have model and seriel # at rear of top load door ready for the technical help person, and they'll take care of it.
Dec 08, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a whirpool model LSQ9200LQ3, serial CRO8155...
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 18, 2010 | Washing Machines
Noise problem related to dim pulsating light
this is caused by the motherboard on this model,have replaced many lately,what happens is when a light bulb in the refrige compartment burns out it creates a surge and burns this circuit board,the clicking is a relay on this board trying to latch,but when the board is defective it cant,when you remove this board it will have a burnt spot on the boards circuit trace and a discolored spot on the case holding it
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Whirpool refrigerator light went out
the light switch may be faulty replace it
Mar 10, 2009 | Whirlpool ED2FHSS Side by Side...
My Whirpool dryer model LXE 7400 WO doesn't
Unplug the dryer.
Remove the back panel.
Inspect the wires at the terminal block where the cord connects.
With a volt meter set for continuity check the thermal fuse on the heater canister(up high). No continuity , replace it.
Check the hi limit thermostat at the heater terminals, no continuity , replace it.
Check the heater terminals for continuity. If none replace the heater.
Remember to remove at least one wire from each part before testing.
Feb 22, 2009 | Whirlpool Dryers
Light bulb burned out in microwave oven
Most likely you're going to have to dismount the microwave and remove the outside cover to get to the bulb. This is a fair amount of work but is not rocket science. I'm not famliar with your particular microwave, but it's probably that way. If it's any comfort to you, light bulbs are usually not covered by warranties or service contracts.
It won't hurt to run the microwave without a bulb.
Feb 03, 2009 | Whirlpool GH7145XF Microwave Oven
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
Michael Thomas
Michael Thomas
jdthefixer
Marvin
Marvin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
