SOURCE: Super G3 brother IntelliFax 3800
Sounds as if the tel line is not connected. 1st check with a telephone, see if you get a dial tone. If not then call the tel company
SOURCE: Brother Fax 4750 System error 76
try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
SOURCE: Fax Problem
Once you have changed the drum unit on Brother 4100 you will need to keep the front door open and then press the option button. Your dispay should give show you a drum change option. press 1 to change drum and the machine should show "accepted" after a few seconds. Afterwards, close the door.
SOURCE: Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
SOURCE: No manual to "Brother Super G3 336kbps IntelliFax-2920"
It is telling you the fuser unit needs replacement. Thats the heater that fuses the toner particles to the paper by heating them. If it cannot reach the correct tempurature the toner comes right off the paper.
So you will need to order a fuser wire kit to fix that error. That can be fairly expensive on a brother. I believe somewhere around $150 and up.
I can at least help you get a replacement manual. This link takes you to the downloads for your printer and you can then download the various manuals.
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_top.html?reg=us&c=us&lang=en&prod=fax2920_us
