SOURCE: NEC Plasmasync 42MP2 Long startup?
If you're NOT still under warrantee you should at least open the TV and check the board where the components are mounted and resoled any that look bad. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
SOURCE: Tv stand required for obsolete model
I have one I bought new. We are hanging the monitor on the wall. Paid $300 for stand, will take $150
SOURCE: Does the NEC plasmasync 42MP2
Hello
The input selection is as follows
You can select RGB source of component source for the 5BNC terminal. When selecting an RGB input the source is selected to RGB input [3], and when selecting a component input the source is switched to DVD or HD input [2].
To select the source with remote control follows. I'm sure that the remote control you have got with with the tv is RD-337 model, and answers.
RGB/PC can be selected using INPUT SELECT button on the monitor. In input switches as follows.
VIDEO-1 ==> VIDEO-2 ==> VIDEO-3==> DVD/HD==>RGB-1==>RGB-2==> RGB-3 and repeats the cycle again as you push the button.
You can also select the by pressing DVD/HD button on your remote contol [right down second button], as source.
DVD/HD can also be selected using the INPUT SELECT button on the monitor and on the remote control's DVD/HD button and the selection series will be same given as above.
OK.
SOURCE: Does NEC plasmasync 42MP2 support
HDCP stand for High-bandwidth Digital Content Protection. It's a way to ensure protection from content piracy at the output on digital connection (that is why component work, as it's analog and not subject to this like some DVI cable or all HDMI and Dipslay Port cable).
The way it protect the data is a bit like for a securized internet connection, using encryption key.
To be able to circumvent this, you need a "HDCP Stripper".
It was invented by Intel and started to appear in 2003 on HDMI cable and (version 1.1 of HDCP) and a bit before that for DVI.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
