Jsmarquez, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (Jsmarquez), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
SOURCE: Dishsoap stays in soap dispenser
Same thing happened to us. We noticed that it happened if the soap was left sitting before starting the washer. Since then, we immediately start the washer after putting soap in it and the problem appears to have gone away.
So much for the delayed start features, but at least the soap doesn't stick anymore.
good luck!
SOURCE: the top rack is not longer getting clean
Using liquid detergent is the worst detergent to use. One possible solution to your problem could be as follows...pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. May need to do this several times (3 to 4). This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel, no liquid and no tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
SOURCE: I have a whirlpool dishwasher Quiet partner 2. I
your problem is hard water. the minerals dry on your glassware causing a white film or residue. go to www.dishwasherfilter.com. they have an awesome product designed for your problem.
SOURCE: my dishwasher doesn't seem to
It will help if you provide the model number of the whirlpool dishwasher.
The wash system for the top arm may be blocked. Hard to tell the exact reason without knowing the model number. Detergent may not be the cause.
SOURCE: Whirlpool Dishwasher leaving chalkie film on
Hi, I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
