Did you replace it with a new one
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica Minolta Bizhub C450
You need to place service call for the transfer belt.
As for Sally's question, select the "seperate Scan" button to combine multiple documents as one file. This will work with or without the auto document feeder.
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
SOURCE: need to reset the fuser counter
Hi there.
Download Service Manual here: http://nodevice.com/manual/Konica_Minolta_QMS_magicolor_7300_Service_Manualpdf/get690.html
and follow the instructions.
Regards.
SOURCE: Can i reset my Konica Minolta C250 transfer unit
On your transfer unit there is a .80 amp fuse you can replace. this will reset your belt. make sure you use .80 amp or it will not work. on your fuser there is an inline 1/16 amp fuse next to the plug you can replace for that.
SOURCE: need to reset admin code for konica minolta c-350
Hello
press utility/counter - then under the counter "details" - stop 0 0 stop 01 -
now you are in service mode, - stop 0 C, and there shold be admin pwd
