Question about Black & Decker 1000w Power Inverter
SOURCE: B&D 400W Inverter won`t run my laptop
Your numbers don't add up. Where are you 'seeing' 200volts. Your lap top power supply transformer uses 120 volts AC. Are you plugged into a 240 volt outlet or something? Your inverter should be 12 or 24 volts DC input; to AC power usually 120 volts AC. Check out you output plug, should read 110 - 120 volts AC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 25, 2009
SOURCE: I have a black and decker inverter type 1 400
First, you should be aware that the exact inverter is available for under 40 dollars all over the US. Your model is sold under several names - check out http://search.harborfreight.com/cpisearch/web/search.do?keyword=inverter .
I suspect that your INPUT power level is not adequate for the inverter to put out the 200W that the 150W charger needs. If you have low current and low voltage - then the inverter can only put out a proportionally smaller AC wattage level. You may also have a faulty voltage sensor....at the input. Once the inverter sees a low level (even momentarily), it alarms and shuts down the output until the unit is reset (turned off/back on)
Posted on Jan 01, 2010
SOURCE: 400W Black & Decker Power Inverter Doesn't Power My LCD TV
The problem of your inverter is from
your battery .your laptop and dvd
player requires little current to
operate.But you tv requires more power
to run, if your battery is low you it will
not last for 3 minutes. If your battery
has a low current rating, it will also be a
cause, for example, if it is below
100ampere hour. Lastly if your battery
is bad i.e. if it reads below the
stipulated dc voltage Require by your
inverter to operate.
Posted on May 10, 2010
SOURCE: trying to run a digital projector from a car battery
I looked at the power requirements of this projector, 280W, but that assumes a nice sine wave. Your inverted is supposed to put out 400W, but it's a modified sine wave. Under ideal conditions (including a good battery) this might be just enough. Connecting directly to the battery will help a little, because of the limited ability to get current to and through the cigarette lighter. Using a 100 foot extension cord will diminish the voltage a bit (less so if it's a heavy gage wire). I would try connecting the inverter directly to the battery, run the engine and skip the extension cord. If that works, turn off the engine. If that works, try the extension cord. If it won't work with the engine running, connected directly and no cord - there are two possibilities: (1) the projector just won't run on a modified sine wave, (2) you need a bigger inverter. --- regarding (1) I have seen lots of people having trouble with various devices. You might want to ask Epson support. --- Good luck!
Posted on May 26, 2010
SOURCE: I just bought a power inverter for use with my pc.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
Posted on Jul 15, 2010
Apr 27, 2014 | Fujitsu Heating & Cooling
Feb 06, 2014 | AEG Washing Machines
Apr 09, 2011 | Black & Decker 1000w Power Inverter
Aug 19, 2010 | Black & Decker Power Inverter PI400AB
Jul 15, 2010 | Black & Decker Power Inverter PI400AB
Apr 22, 2010 | Black & Decker 100 Watt Plug-In Power To...
Apr 05, 2010 | Black & Decker 19" Electric Lawnhog...
Jan 09, 2010 | Black & Decker Power Inverter PI400AB
Dec 28, 2009 | Black & Decker 1000w Power Inverter
Jul 23, 2009 | Black & Decker Electronics - Others
Jan 22, 2011 | Black & Decker 1000w Power Inverter
66 people viewed this question
