Nokia 1100 Logo
Question about Nokia 1100
Restoring factory settings to my samsung u700
Hi, I've been trying desperately to restore factory settings on my samsung u700v, which is locked on vodafone firmware. My problem is the phone automatically saves the top three numbers you text on the phone, and suggests those numbers when you're trying to send a message. I want to pass on this phone and I don't want the new user to have access to these numbers, I checked if those numbers were still there when I put another sim card in, and they were. So am i right in thinking if i reset the phone, those numbers will disappear. The only information i've been able to get is to flash my phone with some samsung software, but i have no idea how I would do that without melting the phone. Thanks very much for your help.
Posted by ellie1985 on
  • stevecally Nov 24, 2007
    I TOO HAVE THE SAME PROBLEM AS THE ONE BELOW. ANY SOLUTIONS?
Anonymous
    Scholar:
  • 117 Answers
Enter *2767*3855#
this will erase all data from any samsung phone. Its a full hard reset. It will only have the info it came out of the box with
Posted on Jan 24, 2008
Anonymous
I have the same problem and I really do not know how to sort it...It is quite annoying....The only difference is that I insert another sim card I do not see those numbers anymore.Hope it helps...
Posted on Jan 05, 2008
Anonymous
    New Friend:
That is what happened to mine and it needs to be flashed.
Posted on Dec 09, 2011
Anonymous
    New Friend:
I used *2767*3855# to rest my u700 samsang.it is showing infor without manu help me how to fix this
Posted on Aug 11, 2011
1 Related Answer
Anonymous
  • 55 Answers
SOURCE: Restoring factory settings to my samsung u700
try this hard formatting type this codes to your phone remove your simcard first *2767*3855#
hope it helps you.....
sexy-ym
Posted on Sep 10, 2008
How do I reset factory setting on a Samsung galaxy s4 cell phone.
    How to do it
    1. Switch your phone off. ...
    2. Hold down the Power, Volume Up and Home buttons at the same time for about 10 seconds. ...
    3. To navigate through this menu, use the volume up/down buttons to scroll up and down and the power button to confirm selections. ...
    4. Scroll down and select Yes - Delete All User Data.
    More items...
    Restoring factory settings on the Samsung Galaxy S4 - My ...
    vodafone.intelliresponse.com/index.jsp?...Restoring+factory+settings...Sams...
3answers
Plz send me the reset code of sgh u700v. imei no. is 35307302151555/6
Hi there, You may contact to your service provider Samsung SGH-U700 Unlock Code, they can open up all networks for you where you want to use your phone. Once your phone is unlock, it will work with any networks worldwide without sticking to one network only. I suggest to visit Samsung Unlock Code site, they will provide you an accurate code fast with easy to follow instructions on how to unlock your phone.
Hope it helps.
Thanks.
2helpful
I have a samsung u450, I am trying to reset my phone back to its factory settings. How do I go about doing that?
WARNING: Restoring the handset will permenently Delete All Data, including Contacts
Note: All locked pictures, videos, ringtones, music, sounds and downloaded content will be permenently deleted when restoring the handset to the default settings.
To restore the handset to the factory default settings follow the steps below:
  1. While in standby mode, press OK for Menu
  2. Select Settings & Tools (9)
  3. Select Phone Settings (6)
  4. Select Security (9)
  5. Enter the lock code, default password is the last 4 digits of cell phone number, unless it has been changed, then press OK
  6. Select Restore Phone (5)
  7. Highlight Yes, using the navigation keys
  8. Press OK to confirm resetting the handset
  9. Press OK at the re-program the phone screen
  10. Enter the lock code again, default password is the last 4 digits of cell phone number, unless it has been changed
  11. Press OK to confirm restoring the handset to the factory default settings
Note: Press *228 and SEND after the power cycle to re-program the phone
Hope this was helpful?
Respected sir, I have installed
Go to the opera mini settings and then look for the access points. Select the access point you currently use with your phone built in browser.
7helpful
5answers
Unlock codes for samsung u700v for tesco mobile
You can get the unlocking code from http://www.mobileunlocksolutions.com/
It helps you to get the unlocking service for your mobile.
Please help me about samsung sgh-u700v
i followed the steps from this LINKand i was able to install games and other applications in my u700 phone. and i swear they're all working fine.
do take note that you have to have BOTH the jar and jad file of the game/app you want to install. if you only have the jad file, just try to install a jar maker OR if you only have a jar file, then try to install jad maker.. good luck! :)
2answers
Unlock code for nokia 6288 locked to optus australia
6402600530 this is for geko2u..sjtt73 pl confirm the IMEI number..
2helpful
2answers
sexy-ym
4helpful
How to delete recent recipients for Samsung soul
if you are desperate enough you could try saving all stuff to memory card and removing before restoring factory settings. this should wipe the list? only thing i can think of?
Jul 15, 2008 • Cell Phones
1helpful
Unlock Phone SAmsung SGH-U700
hi amielle,
     if ur have forgotten ur phone lock code, it won work with any sim u insert...u can't go inside d phone, unless d lock is removed, which is possible if u know d code....so take it to an authorised samsung service centre and tel ur problem....they ll remove d lock and restore it to factory settings...because oly they have d software to unlock ur phone....if ur mobile is within warranty period, this would be done at free of cost....
        best wishes,
        trendsetter
Jul 03, 2008 • Cell Phones
Top Nokia Cell Phones Experts
Muzahura Frank
Kolbrun...
Marvin
Marvin
