Need a manual for BD35 marco fireplace do not now if it is connected properly
SOURCE: marco gas firplace
I have a Model 792864B. Before you attempt to light the pilot light - make sure that any wall control switch or remote control for the fireplace is in the off position. Locate the gas supply line. There should be a gas supply valve to turn on the gas supply. The valve is usually painted a different color than the supply line like blue, green or yellow. Open the valve by pivoting the handle to be parallel to the gas line, usually counter-clockwise. When it is closed it is at a 90 degree angle from the supply line. Locate the pilot light assembly - this is the pilot light. There should also be a red or black ignitor button and a black or green valve control knob with the words "on" "off" and "pilot" on it. It may be located inside a black box, mine is marked heatolator, that has a lift off top. Lift off the top of the box. Push in the valve control knob and turn it until the word "pilot" is in line with the arrow (my arrow is red) or indicator line. While pressing and holding in the valve control knob - it presses in about 1/4", press the red or black ignitor button repeatedly (once per second) until the pilot ignites. Once the pilot is lit, continue to hold the valve knob in for about 30 seconds and then slowly release. The pilot should remain lit. If it remains lit, press in and turn the valve control knob to the "on" position. The on/off wall or remote control switch should now light your fireplace. If the pilot doesn't ignite, turn off gas supply valve, wait about 5 minutes and try it again.
SOURCE: gas fireplace will not stay lit
there is a probe that is in the one of the flame... This once heated builds up enough pressure do to the heat to keep the shut/off valve open... (reason, if the flame went out the gas would continue to flow) this "thermocouple is replaceable !! contact me at [email protected]
SOURCE: Marco fireplace Model 794 cant light the pilot
the valve handle is on when the handle is in line with valve body, off when crossed...are you pushing in on the pilot gas valve under unit? if not.. open bottom panel.. turn knob to pilot..push and hold down while sparking..if pilot lights continue to hold for about 60 secounds.. then release knob and turn to on! Also FYI... these units have a vent recall on them! please go to google and type in your heater, then model #
SOURCE: I recently bought a house w/ a Marco gas
www.macro-fireplace.net is the manufacture's website where you can request a manual for free.
I haven't located any others but I will keep you posted if and when I find one.
SOURCE: How change a Marco Fireplace from wood burning to gas logs
HI best get as gas fitter in to look at this and see if it can be done safer bet
