Hello! I'll need the trouble code to fix your vehicle...Below is procedure with a code list...Guru...saailer
Remove the trim panels in front of the center console.
Locate the engine computer attached to a floor-mounted bracket on the
transmission tunnel between the console and the firewall.
Turn the diagnostic mode selector, located in a round
opening on the side of the engine computer, until it stops. Observe the
small red and green LED lights on the side of the computer next to the
mode selector. They will flash to indicate the modes, with a pause
between each mode. One quick flash is mode one, two quick flashes is
mode two and so on. When the light flashes indicate mode three, quickly
turn the mode selector counterclockwise until it stops. You have entered
mode three diagnostics.
Turn the diagnostic mode selector, located in a round opening on the side of the engine computer, until it stops. Observe the small red and green LED lights on the side of the computer next to the mode selector. They will flash to indicate the modes, with a pause between each mode. One quick flash is mode one, two quick flashes is mode two and so on. When the light flashes indicate mode three, quickly turn the mode selector counterclockwise until it stops. You have entered mode three diagnostics.Observe the red and green LED lights on the side of the computer. The red light flashes to indicate the "Tens" digit of the code and the green light flashes to indicate the "Ones" digit of the code. For example, if the red light flashes two times and the green light flashes seven times, this would indicate code 27.
Turn the ignition key off for two minutes to exit diagnostics. The computer will automatically return to mode one for normal operation...
Code 11 Crank sensor angle
Code 12 Mass airflow sensor
Code 13 Engine coolant temperature sensor
Code 14 Vehicle speed sensor
Code 21 No ignition reference
Code 22 Fuel pump
Code 31 Engine control unit
Code 32 EGR sensor
Code 33 Oxygen sensor
Code 34 Knock sensor
Code 35 EGR temperature sensor
Code 43 Throttle position sensor
Code 45 Injector leak
Code 51 Injector circuit
Code 54 Automatic transmission signal
Code 55 No malfunction recorded
Iām happy to help further over the phone at
https://www.6ya.com/expert/david_6df67de3b14de867
