with the wheel bearings failure , it is very possible that the "U" joint or cv joints for the front drive were damaged
I would be looking in that area especially as you mention on turning right
This typically happens when the front to rear wiring harness has a damaged internal wire or wires. The front to rear harness runs from the front control console, down through the tiller (T part) through the front wheel frame and angle adjustment collar, and through the bottom frame to the controller. There is a wear area of the wiring at the front bearing of the steering tiller. There are 8 or more wires in a covered jacket that run through this area. Over time they rub and get pinched or kinked and broken. The test for bad wiring is exactly what you describe. Usually the broken internal wiring cannot be seen.
The best solution is to replace the entire front to rear harness with the new connectors at each end. The harness is relatively inexpensive and labor should be about 1 hour. Hope this helps.
They are replaceable.
You can knock the broken studs out with a point chisel (wear safety glasses). Take the pieces and nut to an auto parts store in order to get the same nut size (don't want to use two tire tools/wrenches).
Look under the front between the wheels at the tie rod that connects the two wheels. It is probably bent up and should be straight. If it's bent, remove it a straighten it.
