iLO 3200 32 in. LCD Television Logo
A
Anonymous Posted on Nov 14, 2013
Universal Remote Control Panasonic RAK-P001 ilo tv code
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Jul 08, 2007
SOURCE: Ilo 42" Remote Control Code
try the funai codes, 0180, 0179, 0171
Anonymous
  • Posted on Dec 07, 2007
SOURCE: ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
Anonymous
  • Posted on Dec 22, 2007
SOURCE: Ilo remote control code
Yes the Emerson code 198 worked for my jumbo universal remote made my Innovage. I also have the ILO 32' TV and could not find the code but this one worked!!! Hope it helps
lefemmelinda
  • Posted on Apr 02, 2008
SOURCE: code numbers to set up iLo tv
Checked on line for any code there was that someone used for iLo t.v.'s, found two codes on your site that someone had used & used those & one of them worked. Thanks again!
Anonymous
  • 3 Answers
  • Posted on Aug 06, 2008
SOURCE: ilo tv/universal remote codes
Here are some to try, mine was 0189, but there are many to try. 0051 0189 0053 0198 1070 1024 1023. I think some listed codes for Emerson work as well.
1helpful
I have an ilo tv and it is stuck on a blue screen when it is turn on and says composite in the top corner. i've purchased a new universal remote that has some ilo codes but none worked. when i do a...
Hello
It is very difficut to get a substitute remote control for your ILO TV. Anyway try these codes with your present remote control. These codes are with AT&T U-verse remote for ILO TV. The codes are:
1412, 1435, 1436
If these codes does not work with your ILO TV, buy one AT&T U-VERSE remote control. It will match for it. OK.
Rca universal remote (#rcu600ds) no code for ilo tv
I called the number on the Ilo TV. 1-800-289-0980. They suggested trying the codes for either ILO, Orion or Sansui. I got the Orion Code 0135 to work with my new GE remote.
Ilo tv remote control
So far the only universal remote that I have found that works on these TV's is the GE universal remote #24914. The code for the ilo is in the book that comes with the remote. I use this remote...I am able to switch from analog to digital with this remote to. I bought the remote from Target for under $10.
4helpful
2answers
2helpful
2answers
Need remote control code fro iLo TV
iLo Tv's are made by orion. When I used their code the Tv remote worked.
My remote
i got a universal remote for my tv ilo i need a 3 digit number for my tv its a ilo
3answers
Universal RCA Remote controll
I'm not sure what model your remote is, but if there is a code available for an ILO television, you should be able to find it here:
http://tv.rca.com/RCATV/NewTV/Templates/GenericSupport.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2ftechnicalsupport%2ehtml&NRNODEGUID=%7bCDBA69CE-8CEA-435A-8F62-C5E6DBE1ACF6%7d&NRCACHEHINT=NoModifyGuest#
click on the link under "remote control codes" that says "click here"
it will take you to a remote control code finder. just plug in the model numbers and it will tell you if there's a code available.
3helpful
2answers
Code numbers to set up iLo tv
Remote code for ilo: 1286
2helpful
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
