Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
S
S Maer Posted on Nov 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV emits single, loud pop when turned on cold.
  • S Maer
    S Maer Nov 14, 2013
    TV works OK (other than the pop noise).
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Nov 15, 2013
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14994031
Points
237762
It sounds that any electrolytic capacitor at its main power regulator section have bursted out, due to a over-voltage. Contact any service technician. To get more details, http://electronicshelponline.blogspot.com/
  • 4 more comments
  • S Maer
    S Maer Nov 15, 2013
    Thanks for the info and speedy response, Sasi. Any idea what might be causing the "over-voltage?" I don't want to replace caps, only to have other components fail. The TV is 10+ years old. So, should all the larger caps be replaced? Other than the pop noise, the TV is working OK. If possible, I want to repair it myself. I've worked on some TVs and have good soldering skills, but not much troubleshooting experience.
  • The Knight
    The Knight Nov 17, 2013
    Hi Maer, If TV works normal, and you hear a pop sound from its speaker, when you switch it ON, it seems not to be a fault. Sometimes the mute section of the audio output or audio processor section have failed. It will be best not to go further, because, the spare parts to these sets are very difficult to get now. You can check all the solder terminals at the audio processor section. That is all to do.
  • S Maer
    S Maer Nov 22, 2013
    Hi Sasi, Thanks for the advice. Here's exactly what's happening when the TV is turned on. The power light flashes red four times. Then, the TV makes the popping sound. Then, the power light flashes red five times, pauses, and flashes red five times again and the picture appears. If the sound is turned all the way down when the TV is turned off, no pop occurs when the TV is turned back on. I think that means that you're correct about something in the audio section having failed. Any other thoughts?
  • The Knight
    The Knight Nov 22, 2013
    Hi Maer
  • The Knight
    Have you visited the site I've given? If not, just to to it. It has details about the blinking codes to Sony Trinitron TVs. surf it with patience. If you want any more advice, be free to com over by comments. I'm here to assist you, as good as I can. OK?
  • S Maer
    S Maer Nov 23, 2013
    Thanks for taking the time to share your thoughts. As I said, if the volume is turned down when the TV is turned off, no pop occurs when the TV is turned back on. Does that mean you're right about the TV having an audio problem? I had already visited the site. It's great! But, I didn't find any blinking codes for my Sony TV or related TVs. (I only included the Standby LED blinking information in case that was important.) Thanks again for all your help and patience.
Runco TV turned on made a loud pop and now will not stay turned on
Capacitors blew most likely. Take it to a repair shop or learn to open and replace the caps yourself. Could be a fun project.
2answers
Buzz across all channels in crate rfx120
I also have this issue. Same crate combo amp. There is a loud buzz emitted only when there is a cable plugged in. Cables and instruments checked good, only possible issue is inside the input of the amp. Popped it open, solders and connections were intact and appeared solid. Anyone have a guess as to why this is happening?
Feb 12, 2012 • Crate Music
Our tv made a loud pop/crack sound and went
look take the back cover off and look at the pwr fuse its located near the main on/off switch .replace if blown. before you switch back on is the set damp free you could have an ht leak so warm back of set make sure its perfectly dry an hair dryer works well but don't hold too close to single components.if all this works cover set at night with a towel over the air vents when not in use to avoid moisture on line transformer. this answer would work with an ht leak .but the problem could lie elsewhere . good luck farr64
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Problem with Toshiba DLP Projection TV Model #52HM84
It is possible the lamps may be defective or that they may be the wrong replacement for this model, as it may have a different wattage setup with the ballast. If you want to try to order the TB25 lamp from a different vendor, you can order the original Toshiba replacement lamp for this model (52HM84) from a major Toshiba parts distributor at the link below:
Toshiba 52HM84 Replacement Part TB25 Lamp / Bulb
TV made a loud pop
hi,
sounds like a popped power capacitor, its going to have to go to the shop most likely around 100.00 repair. taking the back off yearly and airdusting them helps, especially if you have a smoker in the house. caution high voltage present even when off, the heavy single red wire going to the tube is high voltage be careful.
J
1helpful
Toshiba 50HP66 Blank Screen with sound
I would suggest to read what other members have reported by clicking here.
Good Luck.
Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
