Question about Aastra Telecom Aastra 9316 CW Corded Phone
Need to adjust date and time on screen.
I need to fix the time and date on my Aastra 9316cw phone. When I got to work this morning they were wrong.
Posted by jess_gilmore on
Anonymous
    New Friend:
Just above the Hold button, with the Aastra name display, that is a sliding piece that will uncover your setup menu button. Press that and navigate to time/date settings.
Hope this was helpfull.
Posted on Nov 03, 2009
Sid
  • 483 Answers
The red light on my Aastra phone 9133i does not blink when I have a voicemail message
Phone your provider and ask them to turn on the indicator light. If you hear beep beep beep when you have a message they have it set wrong. Tell them you have a red light on your phone. They just set it incorrectly . Happens all the time hope this helps
Oct 24, 2013 | Aastra Telecom 9116 Corded Phone
How to adjust date and time free of charge
You did not specify the phone you using.
To set date and time on your nokia phone
Select Menu > Settings and Phone > Date and
time.
Select from the following:
Time - Enter the current time.
Time zone - Select your location.
Date - Enter the date.
Date format - Select the date format.
Date separator - Select the symbol that separates days, months, and years.
Time format - Select the time format.
Time separator - Select the symbol that separates hours and minutes.
Clock type - Select the clock type.
Clock alarm tone - Select the tone for the alarm clock.
Alarm snooze time - Adjust the snooze time.
Workdays - Select your working days. You can then set an alarm only for working day mornings, for example.
Automatic time update - To update the time,date, and time zone, select On. This network service may not be available on all networks.
Regards
Jun 30, 2011 | Lands Phones
I have a Aastra Telecom 9316CW Corded Phone and I have lost my manual. I need to know how to turn the light back on in the window. Please, please let me know or tell me how I can find out. Thank you. ...
Do you mean the feature light or the backlight for the display? The feature light can be set to on or off.
To set the light, press Save then 1 (for light on) or zero (light off). Press the desired memory key to associate with the feature and then enter the code from your telephone provider for that feature. Press Save and then label the memory key.
To use the feature light, press the memory key (as selected above) and then lift the handset. Press either Handsfree or Mute. The feature and the light will turn on or off. When the phone is not in use, then Feature On will be seen in the display.
The backlight is not adjustable. You can adjust the contrast with the Contrast button. Backlights do fail over time (but it's not a repair I recommend if the phone is out of warranty).
The manual is available here: http://www.aastratelecom.com/cps/rde/xchg/en-ca/hs.xsl/21564.htm . Look at the bottom of the center section for the PDF.
I hope this helps.
Mar 03, 2011 | Nortel Lands Phones
How to set date and time on aastra 5370
I suggest you consult the user manual.
You can get it in PDF format here : http://www.aastra.com/cps/rde/aareddownload?file_id=7959-13627-_MAS_XML&dsproject=aastra&mtype=pdf
Please rate if this answer helped.
Thank you!
Feb 28, 2011 | Aastra Telecom Aastra 8314 Corded Phone
I've lost my user manual and I need to reset the date and time.
I lost a user manual, then found this site called find my manual. They emailed it to me in about 2 hours and it only cost about £3, which i thought was very reasonable.
http://findmymanual.com/
Hope this helps.
Jane
Jul 14, 2010 | NorStar Aastra M5316 Phone, NT4X42 (Un,...
How do I call forward this phone to my cell?
Forwarding is through the plan provider and part of the voice mail system.
Feb 08, 2010 | Aastra Telecom Aastra 9316 CW Corded Phone
Cannot get "for free service press O.K., etc." off my screen
Bell has discontinued their process to wipe out the ad. Aastra Telecom manufactures this phone and has a 9 step procedure to clear the Bell I-Select Advertisement. Herre's a copy:
WARNING: This procedure will permanently erase the Callers List and Directory in your 390 telephone. Please record important names and numbers before implementing this procedure. This procedure disables the programming of the idle screen, so it will not only get rid of the ads permenately but you will also lose the ability to program any of the softkeys on the idle screen as well.
1) Press the Options button (the short button below the orange Goodbye button)
2) Press the Down Arrow 4 times or until the cursor points to Area Code and press Show
3) Press the Down Arrow 2 times or until it points to entry 3.
4) Press Change
5) Enter 0099 and press Done 2 times to return to the Options Menu
6) Press Up Arrow 3 times or until the cursor points to Time/Date and press Show
7) Set the Date and Time to Jan 01 12:00am and press Done
8) Press Goodbye to return to idle screen and verify the Date and time are correct
Before the time changes to 12:01am perform the next step (if the time does change, return to step 7)
9) Press these keys in sequence: Option, Mute, 0 (zero)
Your telephone will reset and the Ad message will be permanently erased.
Mar 25, 2009 | Aastra Telecom Powertouch/Vista 390 Corded...
How do I erase the "I Select" features from the Vista 390 screen?
None of the phone numbers I have to delete this annoying problem work anymore. Is there another solution out there?
Feb 02, 2009 | Aastra Telecom Powertouch/Vista 390 Corded...
Aastra 9110 Single Line Corded
Press the setup key and use the down,up,across arrows on the upper of the set below the window to find the date and time. Let me know if you get it done.
Feb 18, 2008 | Aastra Telecom Aastra 9110 Single Line...
Aastra Telecom Aastra 9316 CW Corded Phone Logo
813 people viewed this question
Top Aastra Telecom Lands Phones Experts
Marvin
Marvin
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
