The cd player motor or laser won't work, the motor doesn't seem to spin and the laser won't read the disc. What can be don't to fix the problem?
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Thank you for using Fixya
Now since you have changed with a new one ( please make sure that the solder jumper was removed which is for static damage security in the new unit)
I have a Durabrand Cd/MP3 player and I accidently hit the top of my cd player and when I tried to play a cd it won't spin. Is there a way to fix it without buying a new one cause I got a new cd player but it won't play mp3 files up to so many minutes help me out.
I have a cd player that for some reson the cd doesn't spinn and the lazer dosen't seem to turn on!!!!! Please help!!! Thanks in advance!!!
