Question about Tefal Irons
I have a Tefal Pro express iron and I have water dripping out of the bottom of the generator. Can you help.
Posted by petrawill on
Samuel Charles Spriggs
    President:
  • 1,489 Answers
There is a seal or a connection leaking. Take the iron apart -- you'll probably see where it's been leaking.
Posted on May 04, 2009
Tefal 2932 pro express iron not steaming
Use different water in the iron...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 14, 2010 | Tefal Ultraglide 1549 Iron
Seeking stopper for Tefal pro 2500 1875 steam iron/generator
I too was looking for one
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=146230&query=tefal%20stopper
cost £20.99
Nov 01, 2009 | Tefal Irons
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Feb 17, 2009 | Tefal Irons
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Irons Logo
1,565 people viewed this question
Top Tefal Irons Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Harrie
Are you a Tefal Iron Expert? Answer questions, earn points and help others
