Try unplugging as suggested. Also, try different inputs (HDMI, component, etc.) and different cables to be sure it's not some external item causing problems or just one input. Also plug it into an outlet on a different circuit in your house.
If everything you try still shows the lines, it's probably the screen itself and is too expensive to fix.
SOURCE: SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
* With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
* The TV will turn On with the Service Menu displayed.
go to reset
* Press the {POWER} button to exit the Service Menu.
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
