Question about JVC AV-20220 TV
Zenith menu without remote
Trying to program without remote control
Posted by MissCarol on
    Top Expert:
  • JVC Master
  • 76,455 Answers
Without a remote control, you can't program it. If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. For more information; check the links given below, and find which brand remote control has setup codes to your TV/Device brand. Setup code list & setup procedure to some popular brand remote controls are given. Check it, and determine which brand remote control should be bought, and buy that brand remote control, according to availability.
For more information, check these links.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Posted on Nov 14, 2013
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
I have a toshiba tv without a remote and I'm trying to set up my magnavox to the tv without a remote and can't figure it out.
Buy a universal remote control and program it to work with the television and DVD player you have.
May 04, 2015 | Toshiba Televison & Video
WHICH UNIVERSAL REMOTE CAN USE FOR THE KOGAN HD TV?
Try procedure to program remote without code.. Look manual how to do it, it's different doe each remote
Jul 05, 2014 | One For All URC-3021 Remote Control
Need program codes for my RCA Gemstar remote control.
Without model number it is hard to be sure which code list you need. Try the link below:
http://remotes.com/remotes/documents/RCA/CRK76TA1.pdf
Dec 28, 2011 | RCA Televison & Video
How to program a haier flat tv and a supersonic DVD player with a jumbo innovage remote control?
There is a way to program this remote to devices without the codes. If it is possible to install the device to this remote at all, this will do it.
This is an alternative method to programming your device without using the code list. The remote control will scroll through the list of codes to identify the correct code for your device.
  1. Turn onthe device that you want to set.
  2. Aim the remote control at the device and press and hold down the CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
  3. Press the device button for the item you wish to program, e.g. TV,DVD,VCR, etc. and the LED light will blink once and then remain solid red.
  4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to program shuts off. (Note: LED will blink once each time you press ON/OFF button).
  5. Once this occurs, press ENTER button to store the code and the LED light will turn off.
May 05, 2011 | Innovage Jumbo Remote Control
Cannot find remote code for panasonic TV/VCR combo for RCA remote
Here is a list of codes for your remote. Please follow any of the links below to get your codes.
Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
Search Results
  1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
    www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
  2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
    www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
  3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Unable to program the remote to my mognavox
UNABLE TO PROGRAM MY REMOTE TO MY APEX TV I NEED THE CODE.
Jan 29, 2009 | RCA RCR450 Remote Control
JVC AV-20220 TV Logo
164 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
