Webcam works on msn but the picture is black and fuzzy
My webcam will work fine when im taking photos but when someone askes me to go on webcam over MSN messenger it comes up with a black fuzzy screen with no picture at all.
m/n:v-um14 p/n:861092-0020 s/n:lza43950243 made in chinai want dawn load driver webcam logitech
AnonymousMay 25, 2009
it works fine on instant capture, but on msn its black and fuzzyit works fine on instant capture, but on msn its black and fuzzy
You can't post conmments that contain an email address.
Re: webcam works on msn but the picture is black and...
Go to Logitech's website...click on your product model and from there you can download the latest drivers. Make sure to note that most device drivers for Vista 64 bit systems are different from 32 bit. Hope this helps.
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly. The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted. Mine, I just unplug it from the USB and plug it back in to reboot the software. If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN Click 'Open Menu' From 'Tools; navigate to, and click, 'Audio and Video setup' Set your speakers Click 'Test' - if OK, move on. Set your mic as default Use the slider to set volume and test. Click 'Next' This takes you to the video setup Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN Use 'Webcam Settings'to fine tune the picture. Click 'Finish'
There may be a clash between lifecam and MSN. close MSN and alll other IMs. uninstall lifecam. restart the PC, install webcam SW with the cam unplugged. After installation plug the cam ina USB port and let Windows read the drivers and install the cam, Once that is done, now you can configure the cam in your IMs one by one.
Normal
0
Try disconnecting the camera from the USB port and reinstall
the CD software program. When the program asks you to connect the camera to
the USB port, do so and it should work. Sometimes it takes a fresh install to clear problems. Worth a try. Hope this helps. Bud
Normal
0
Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall
the CD or Downloaded software program. When the program asks you
to connect the camera to the USB port, do so and it should work.
I brought a philips spc110NC Web camera its just a plug in and work and it works fine on msn, but i do not know how to work it on yahoo, does it really works on yahoo and how should i let it work? thank you
I can use the webcam on Skype but when I close Skype and open Instant Messenger I get a message that the webcam is unplugged or being used by another application.
