Bosch BSG81313UC Premium Bagged Canister Vacuum Logo
A
Anonymous Posted on Nov 14, 2013
Husky 291322 cord reel when pulling cord out the cord will not "catch" and hold position
Spring appears to work but will not lock in position
How to get to wiring plug
If you're talking about the cord that you pull out from the reel located at the rear of the machine, you'll have to take the top cover off first. Usually two philips head screws located under rear exhaust cover and one maybe two near the front end. Once that is removed, there will be two more philips screws, one on each side of the top rear of the machine and one on the bottom. Remove all three of them, pull about a foot of cord off of the reel and get it to catch, the using the heel of your right hand, hit the very back of the machine, (the rubber bumper part) on the top with a motion pulling toward the back. This may take a couple of tries if you're not used to removing this part, but one or two swipes should eventually loosen the rear cover. Once it is loosened you may carefully pull it out of the back end of the machine and take off the two wire connections. This will free up the cordwinder assy. so you can take it to a spot where you have some room to work. Now lay the assembly on it's back and take the four screws, one from each corner of the rear cover, out and lay them aside. Thread the cord plug through the opening and wind the free cord back onto the reel, allowing the spring to pull it slowly out of your hand and then wrap the plug end around and around the reel till the spring is unwound, then you can remove the "C" clip from the center post, sometimes hidden under a cardboard washer. With the clip removed you can gently pull the cord reel up and off the post, carefully bringing the rewind spring up and off it's post as well. If you've tested the cord and are sure that it's your problem then you can cut the remainder of the cord from the reel and throw it away. The reel is easier to deal with without the cord on it. Turn the reel over so the back cover is exposed, there should be three screws that can be removed so you can take the connections loose from the posts inside and make ready for the new cord. Once you've attached the new cord and tied your strain relief knot, like the one you removed, you're ready to wrap the cord onto the reel and just reverse the procedure. When you get ready to put the loaded reel back into the cordwinder body, just before you put the cover on, wrap the plug end around the reel three times. This loads the spring so that it will pull the cord completely back into the unit. And it doesn't hurt to drop a spot of oil onto the top of the post for the spring.
Husky power cord reel won't retract
spring in cordreel is sprung. cord is probably on last leg. Go to vac replacement parts online store and order a new one.
Feb 04, 2013 • Vacuums
1helpful
2answers
VACUUM - 1. How to open up a Wertheim 5030 to get to the cord retractor 2. How to fix the retractor so that it retracts the cord.
Hi to do this you will have to somehow find a service manual, this will give detailed instructions on why and how. I have searched for one however i was unable to find any. Perhaps a direct plea to the manufacturer may help?
In any event, usually the is NO "Fixing" of the retractor, most often, the mount at the rear attachment of the coiled spring, brakes and this stops it retracting.
The fix is to replace the entire recoiler assembly. This is pretty simple job, if one can obtain the parts.
However my professional advise is to take it to a vacuum repair shop, (NB: Only take it to a repair shop that deals in YOUR brand) and ask for a "Quote" for the repair, I am sure it will be modest indeed. You see this is just such a common thing that they fix all the time.
Mar 26, 2011 • Vacuums
Frayed power cord on electrolux canister vacuum
1 screw in the front, two in the blower port. take them out and the top bezel comes off. one screw in the bottom and two on the top. need a flat blade screw driver to pry out the cord reel. 4 screws holds the sheild of the reel. take them out and there is a snap ring that hold the reel on the shaft. the reel assembly and drum spring comes out at the same time. 3 screws on the bottom of the reel holding a metal plate and there is also snap ring hold the spring on the metal plate take that off and will expose the cord connection. unhook the the cord and untie the knot and replace the cord and reverse the process
3helpful
The cord on my electrolux Epic 6500 has been pulled too far out and will not rewind. How can I access the cord reel to rewind?
There are two keys holding the body together, underneath the bumpers on the side of the vac. With the bag door open these keys when gripped with pliers will slide forward to release the body panels.
Before opening the vac, gently push the cord back inside the housing.
2 possibilities:
If the spool rotates and allows the cord to push in , the body must be disassembled, and the cord winder removed and the spring reloaded. This is tricky work. you will need to wind the entire cord onto the spool, then load 3.5 rotations onto the coil spring for tensioning, then reassemble. It's a bit like working on a land mine of you're new at it. Wear safety glasses.
BUT if the spool is locked from the outside and the cord wont push in or pull out, a fine , long blade screwdriver can be inserted diagonal to the body through the cord slot and with luck you can lift a cog of the spool releasing tension and the rewind will work. try that first , but be gentle . You must release the cord spool allowing a a dog ear catch cog to release inside by gently lifting upwards.
Post back to say how you made out,
Or look for an AERUS Electrolux service shop.
2answers
Yanked the cord out of the vacuum
Wasn't able to find any diagrams either, but there should be some screws to take out, and the top and bottom should separate. Don't let the cord reel spring unwind if it hasn't already done so. If it hasn't, one half of the reel should come aprt so you can re-attach the cord. then put the reel back together and let it wind the cord on the reel. If the spring is unwound and/or the reel wasn't made to come apart, then you will have to replace the cord reel asm.
1helpful
Electrolux Oxygen 3
Most cord reels have a stop on it, it is a rubber wheel and when dust gets on the wheel, they won't always stop the reel. It would have to be opend up to get to the cord reel, then you could clean it out.
12helpful
2answers
Won't Turn On
Mine was a simple fix. Hope yours is too.
You need to take the unit apart to get to the cord reel. If you don't know how to take your unit apart, here are some instructions on how to take apart most of the Miele canister units.
http://www.sannerud.com/house/miele.html
Once it is apart, you will need to take out the cord reel. There is a small rubber hose which needs to be removed on the outermost part of the reel. Then there is one small silver screw that you must remove as well. One these two items have been removed, carefully lift the entire cord reel assembly upwards. When you are doing this, ensure that you are also lifting the black and white wiring along with the reel - just make sure that you're not yanking it and possibly breaking the connectors off. As you lift the entire reel assembly out, you can also remove the white wiring harness which connects to the main switches on the vacuum.
Now, here is the trickiest part - not really that tricky if you are good with your hands.
First, make sure that the cord is retracted fully. Then, start pulling the white plastic cord reel away from the black plastic assembly about 1 inch or so. Between the black assembly and the white reel, you'll notice a copper-like metal spring which is attached to the white reel. Make sure that as you are removing the white reel further, that you are maintaining visibility with the copper-like spring. DO NOT LET THE SPRING OUT OF ITS OWN WHITE REEL (the spring has its own reel which is difficult to wind up again, so be very careful!).
Make sure that the spring is fully retracted at this time. If it is not, wind the reel so that the spring is not wound up anymore around the white reel. Carefully slip the spring out of the white reel and leave the spring as-is ensuring that it does not unwind itself out of its own reel.
Now that you have the white reel off the black assembly, inspect the inside of the inner part of the white reel. You'll see two copper rings with 'wings' on them. These wings transfer power to the vacuum. There may be some grease (black) which you should wipe off with a paper towel. Also wipe the metal rings on the black assembly which touch these 'wings'. (the wings touch the metal rings to send constant power to the motor. The wings are there so that as you wind and unwind the power cord from the vacuum, there is always constant contact with the metal rings on the black assembly.
Now, carefully pull the wings up and out. If you can picture it in your head, what you're doing is ensuring that there is a good contact between the copper wings and the metal rings on the black assembly. Do this for all 4 wings on both the inner and outer copper rings within the white reel. Make sure that the 4 pads are clean and grease/dirt free.
Once you've done this, it's time to put the white reel back on the black assembly. Do everything you did earlier, but in reverse.
Carefully take the copper spring and align it to the white reel - you'll see a specific slot where the spring slides and grabs onto on the white reel. You'll probably have to place the white reel slightly onto the black assembly rod in order to achieve this - again, you must be good with your hands to do this without breaking anything.
Once the copper spring is attached to the white reel, press the rest of the white reel onto the black assembly. HINT: turn the white reel slightly so that you're applying some tension on the spring - this will make sure that the spring doesn't fall out of the white reel.
Reassemble the cord reel assembly (black and white parts) back into the vacuum. Make sure that the black and white power cables are out of the way. Once seated, wrap the black and white cables around the assembly and reseat the white wiring harness. Reapply the black rubber tube to the cord reel assembly and replace the silver screw to hold the entire harness down.
Close the vacuum casing, replace the control panel (power and cord buttons). Close the unit, plug it in, and power it on!
If it worked for you, congrats! If it didn't, sorry, you've got a much bigger problem with your unit.
1helpful
4answers
Miele .s5210 Bag Vacuum
either the switch or the motor has burned out. try resistance test on each. look for positive resistance change on switch and about 2 ohms on motor. also look for a disconnected wire
Top Bosch Vacuums Experts
john h
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
