Restoration Hardware Maison 12-Drawer Dresser Logo
A
Anonymous Posted on Nov 14, 2013
How does one remove the drawers?
How do i remove the drawers from a LIGNA Dresser 1626
Pull drawer fully forward, hold front of drawer and move it upwards, pull back gently and it should come out.
How to remove drawers from a legacy brand dresser
Pull the drawer out as far as it will go, then gently add more force and it will come the rest of the way. Be careful putting it back in because the plastic stop at the front end of the center slide is easily breakable.
1helpful
Can't remove drawers from Hayworth mirrored 4 drawer dresser
I'm not sure about the dresser drawers, but for the night stands and the armoire, pull the drawers all the way out. Feel under the drawer (towards the middle back), and there should be a plastic tab. Push the tab down toward the floor and pull the drawer at the same time. It should come right out.
Drawer will not close on child craft 3 drawer dresser
Make sure the drawer is either nailed or glued together properly...also try a little lubrication on the sides od the drawer to make it slide in easier.
AAmerica dresser drawers don't open all the way. How to remove the dresser drawers.
Try some lubrication on the sides of the drawers...may make it easier to slide out.
1helpful
Can't remove dresser drawers
on some dressers there is a little button under the draw in the center that you have to push in order to allow the drawer to come completely out
Removing a drawer from Target Dresser
Pull the drawer out as far as you can, then lift the drawer a little while still pulling it out gently.
Removing a dresser drawer from a Kinderkraft chaning table #225
There are two metal tabs above the gliding rails on each of the drawers. Push them downward on each side simultaneously when the drawer stops. You may have to do this twice for each drawer; KinderKraft probably put this in as a safety precaution because it is nursery furniture.
Top Restoration Hardware Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Restoration Hardware Furniture Expert? Answer questions, earn points and help others
