Question about HP OmniBook 500 Notebook
How can i reset CMOS/BIOS password for HP compaq tc4400 laptop i have hp 500 notebook and i forget cmos/bios password . i remove cmos battery . but dont solve it . how can i solve it
Posted by arash1356 on
Anonymous
    New Friend:
Posted on Apr 16, 2010
Frank Fernandez
    President:
  • 778 Answers
Shut down PC, unplug power supply, remove battery, then remove the CMOS battery for 5 to 10 minutes. Reverse above order and check your system.
Posted on May 04, 2009
1 Related Answer
stranger_ab
Abhinav Rai
  • 133 Answers
SOURCE: bios password for HP compaq tc4400 laptop
Don't try anything. Simply contact the HP tech. support team. They will help u come out of the trouble.
I just want to know how can i reset my bios password ?
The simplest way to remove a BIOS password is to simply remove the CMOS battery. A computer will remember its settings and keep the time even when it is turned off and unplugged because these parts are powered by small battery inside the computer called a CMOS battery. If we pull out this battery, the computer will forget alot of its hardware settings, including its BIOS password.
Hope this helps.
Cheers!!
Dec 30, 2010 | HP Compaq nx9020 Notebook
I FORGET MY LAPTOP BIOS PASSWORD WHAT CAN I DO I HAVE HP COMPAQ 610
i,
To reset the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Dec 27, 2010 | HP Compaq Motherboard
Forget my bios password notebook hp 6720s
Removing the RTC battery and leaving it uninstalled for 5 or more minutes causes all passwords and CMOS settings to be cleared. BIOS password can be removed by temporarily disconnecting/ removing the RTC/ CMOS (Coin-cell) battery from the motherboard. Disconnect the coin-cell battery from the system board and it will reset the BIOS to its default setting and the password would be gone.
Please Refer to Page 77 of the REPAIR MANUAL HP 6720S.
If you can't do it yourself, you may seek help from local laptop service professional.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 22, 2010 | HP Compaq 6720s Notebook
I have HP TC4400 Laptop and there is BIOS password which is forgoted please help me how can i remove that password.
To reset the BIOS password read the information from this link.
In case of your HP TC4400 laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 16, 2010 | Compaq tc4400 Tablet PC
Bios password for HP compaq tc4400 laptop
Apr 16, 2010 | HP OmniBook 500 Notebook
Give me password for compaq evo n600c
You can remove your bios password by reseting your CMOS battery or jamper. You need to open your notebook remove first the battery and all screw at the back of your notebook. You can see there a CMOS battery together with the CMOS jamper. Just read it you can read CLRSCR which means clear cmos, just pull it with in 10 seconds and insert it back. Now you are done to reset bios.
Mar 03, 2010 | HP Compaq Evo Notebook N600c
Crack bios password on compaq nc6320 - please
You can crack dell bios password with Windows Password Recovery Tool 3.o . Here is a good post to help you:
http://www.windowspasswordsrecovery.com/crack-dell-laptop-password.htm
Oct 09, 2009 | HP Compaq nc6320 Notebook
I neeed clear bios cmos and cmos run to my hp ze4315us
Restart system holding down f11 key till it beeps. Dont forget to backup your documents.
May 26, 2009 | HP Pavilion ze4315us Notebook
HP OmniBook 500 Notebook Logo
3,572 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
