Question about Apple iPod nano
I woke up this morning and noticed my IPOD nano silver 2GB displaying a disk mode pn th top of the screen with a huge checkmark in the middle of the screen and the phrase ok to disconnect on the bottom of the screen. Furthermore it appears that the IPOD won't turn off because the battery keeps running low and the menu won't respond. It's frozen on the screen that I've mentioned above.
  • 562 Answers
Reset Ipod.
Make sure power switch is on.
Press and hold center button.
next press and hold "menu" on the ring.
When a Apple logo appears on the screen let the buttons go.
Should take just a few seconds.
Posted on May 04, 2009
6ya staff
SOURCE:
My old style nano 2g has disk mode displayed on it - ok to disconnect.... appears frozen
This solution for the ipod white screen of death also has how to get out of the disk mode
http://www.zolved.com/synapse/view_content/19067/The_Apple_iPods_White_Screen_of_Death
Nov 12, 2009 | Apple iPod nano
Ipod nano 2gb screen locked
You can follow this link it will give the details of ipod screen lock http://support.apple.com/kb/HT1350
Jun 18, 2009 | Apple iPod nano
Nano Ipod stuck in disk mode:
Simply reset the iPod
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Jan 31, 2009 | Apple iPod nano
Ipod Nano 8gb won´t synchronize
Try this.
  1. Put the iPod into disk mode by holding the menu and middle keys together until the screen turns dark.
  2. Then quickly hold both he middle button and play/pause buttons until the iPod shows a check mark and the words disk mode at the top.
  3. ThenClick on iTunes to open it.
  4. Connect the iPod to the computer. You may have to do a restore depending on what iTunes says you need to do.
If this doesn't work, check the bottom of the ipod where you connect the cable. See if there are any bent pins. These are very fragile and can be damaged if you insert or pull the cable out the wrong way. Hope that helps.
Dec 19, 2008 | Apple iPod nano
My nano hang!
If your ipod just hangs, have you tried doing a reset by holding the menu and middle buttons?
If that doesn't work, before you connect it to your laptop, make sure that you have the latest iTunes loaded on your laptop.
Hold the menu and middle buttons until the screen goes black and then quickly hold the middle and play/pause button until you see a checkmark and the words disk mode. Now connect it to your computer and do a restore.
If it doesn't check the connector at the bottom. You may have some bent pins in the connector at the bottom. Unfortunately, that will cause communication problems with the computer and ipod. Hope that helps.
Oct 28, 2008 | Apple iPod nano
Middle of screen is blank
Your screen is probably damaged, and will need to be replaced, but try these:
The 5 Rs: Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with iPod nano. Try
these steps one at a time until your issue is resolved. If one of the following doesn’t
help, read on for solutions to specific problems.
â Reset iPod nano. See “General Suggestions,” below.
â Retry with a different USB port if you cannot see iPod nano in iTunes.
â Restart your computer, and make sure you have the latest software updates
installed.
â Reinstall iTunes software from the latest version on the web.
â Restore iPod nano. See “Updating and Restoring iPod nano Software” on page 50.
Jun 02, 2008 | Apple iPod nano
Unlock screen on silver 2GB nano ipod
more info will be helpful,
is it locked with the lock feature ?
or frozen?
if it's the lock feature u have to use itunes to unlock the nano.
May 13, 2008 | Apple iPod nano
Ipod nano
Well try to format the ipod when its in disk mode.. go to my computer find the ipod right click and format
then you need to restore it with itunes
heres a guide
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
May 02, 2008 | Apple iPod nano 3rd Generation
IPOD NANO 2GB SILVER
try resetting ur ipod by pressing both the menu and center key together till u see an apple symbol
Apr 24, 2008 | Apple iPod nano
CheckMark On My 1-Gig Nano
Your iPod is in Disk Mode. Press and hold the menu and select buttons together until an apple appears. then it should be Ok. More info can be found here: http://docs.info.apple.com/article.html?artnum=93651
Nov 10, 2006 | Apple iPod nano
Apple iPod nano Logo
117 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
